    Can this be done with SU?
    7 Posts 3 Posters 1.2k Views 3 Watching
      rodman100
      Stone Wall.jpgI have a surveyors AutoCAD file in 3D of a curved stone wall that I would like to model in SU. The wall is irregular in that the top is not vertically above the base at any point and I can't figure out how to make faces between the two strings. This is a small section of a very much longer wall & I wonder if a plugin would solve the problem. Any ideas anyone?
        maybe this can interest you! 😉
        and if you got to the French Section : Settings / Usergroups/ Français/ Summit (bottom page)...
        https://sketchucation.com/forums/viewtopic.php?f=51%26amp;t=67221
        You have 3 page about walls stones buildings! 😉
        By Chri
        DAMEUSE2.skp
        • andybotA Offline
          andybot
          Maybe you could try skinning with Fredo's curviloft tools? http://sketchucation.com/forums/viewtopic.php?t=28586
          If the lines don't match up well, I would suggest using the BezierSpline plugin to make an equal number of points between the top and bottom (polyline divider tool)
          Andy
            rodman100
            Thanks @andybot, I think Fredo's curviloft tools is the way to go, just need to figure out a work process to get from a CAD polyline to the SU model, haven't ever had to use his amazing plugins before!
              rodman100
              I installed Fredo6 Curviloft as suggested and I achieved this almost straight away! Many thanks!
                So it's a texture of stones ?
                  rodman100
                  I made a texture material from a photo of the stone wall & then applied it to the surface created by skinning the top and bottom lines.
