    Draw line by color
    11 Posts 4 Posters 1.7k Views 4 Watching
    • boofredlayB
      boofredlay
      Is there a plugin that allows you to draw a line "in color" rather than drawing it and painting it?
      I do quite a bit of stucco joint lines. I sometimes place them in a group and color the group but most of the time I will draw them directly on the surface then paint them individually. It all depends on the model makeup. For the second option it would be nice to be able to draw the line already painted.
      Thanks.
      • boofredlayB
        boofredlay
        Ooooo, found it!!!
        https://sketchucation.com/pluginstore?pln=ChrisP_ColorEdge_EN
        Hmmm, seems an old plugin with problems.
          Yes that is by a French guy! πŸ˜‰
          • boofredlayB
            boofredlay
            OUI
            • boofredlayB
              boofredlay
              Well unfortunately it does not perform as well as expected.
              It won't draw lines inside a group or component. While in edit mode it will draw the line outside the group or component, then you have to copy paste it back in. Not too efficient.
              Maybe there is another that works as expected?
                Ask to Sdmitch or TIg for a more precise tricky plugin! πŸ˜‰
                • CadFatherC
                  CadFather
                  not sure if this can help.. the below routines will paint all selected edges with random colours
                  perhaps you can integrate it with a keyboard shortcut
                  this will paint each edge differently
                  @m = Sketchup.active_model; @s = @m.selection ; @mt = @m.materials ; @st = @m.styles
                  @m.rendering_options["EdgeColorMode"] = 0
                  @s.grep(Sketchup;;Edge).each{|m|
                  mat = @mt.add("edge")
                  mat.color = rand(255),rand(255),rand(255)
                  m.material = mat }
                  @s.clear
                  this will colour the surrent selection set with the same colour
                  @s.grep(Sketchup;;Edge).each{|m| m.material = mat }
                  @s.clear
                  • boofredlayB
                    boofredlay
                    Thanks CadFather. I am looking to draw a line already in color but I will look at this.
                    I posted the issue in the plugin thread for ColorEdge.
                    • CadFatherC
                      CadFather
                      ok, and that should be possible using observers, meantime if you were to use 'model._active_edges', instead of a selection - you could capture all edges in the current context - this can be quick.
                      below is a better example (will use existing material if already used) - right now colour set to orange
                      @m = Sketchup.active_model ; @ae = @m.active_entities ; @mt = @m.materials ; @mat = nil
                      if @mt.to_a.include?(@mt['edge'])
                      @mat = @mt['edge']
                      else
                      @mat = @mt.add("edge")
                      @mat.color = 255,128,0
                      @ae.grep(Sketchup;;Edge).each{|m| m.material = @mat }
                      • FrederikF
                        Frederik
                        This could be very interesting...
                        Would colored lines remain colored in LayOut...?
                        Edit: Just to answer my own question, the answer is - YES... πŸ‘
                        Colors are remaining in LO even when converting to vector...! πŸ˜„
                        Cheers
                        Kim Frederik
                        • boofredlayB
                          boofredlay
                          Nice.
