    MSPhysics disappearing drawing
    3 Posts 2 Posters 1.0k Views 2 Watching
      Mark205
      Hi all, i have just downloaded MSPhysics and i'm starting to learn it. After i do a couple of operations the drawing starts to melt away so i have to reset. I assume i missed something in the small print with the free version and to prevent this i will need to upgrade? Thanks.
        Anton_S
        Hello, Marc,
        This is because there are hidden objects and/or layers in the model that fall too far away from camera. Unhide them, set their state to ignore (MSPhysics->State->Ignore), and then hide them again.
        If one of the visible objects fall down too far as well, simply add a floor or container below them, so that they don't fall beyond it. Also, enabling continuous collision option, will prevent objects from falling through each other. So, enable it in case they do.
        Anton
          Mark205
          Thanks Anton appreciate your reply. I will try your suggestions. Fairly early on the learning curve for me, cheers.
