    Problems with installing Plugins
    3 Posts 2 Posters 726 Views 2 Watching
      amihumi
      Hello,
      I use SKETCHUP 2016 whose installation file I downloaded from http://www.sketchup.com
      When I try to install plugins on the software, not all the plugins work.
      This problem is repeated on both computers.
      Are there settings on my computer that I need to set up differently?
      I have a desktop PC with Intel Core i7-4770K and a NVIDIA GeForce GTX 760 oc 4gb video card.
      In addition, I have a DELL PRECISION laptop with Intel Core i7-6820HQ and NVIDIA GeForce GTX 760 oc 4gb
      Are there any settings I need to change to make the plugins work?
      Another question is, are there recommended video card settings for vrey for sketchup to function optimally?
      • PixeroP Offline
        Pixero
        It's a bit hard to know the cause of your problem with so little information.
        Do you get any error messages when starting SketchUp?
        What does the Ruby console look like? Any info there?
        Some plugins need other plugins (libraries) to work (like Thomthoms and Fredos).
        Are you using the Sketchucation Plugin Store for installation?
        If not I recommend it as it makes it super easy to install and update plugins for SketchUp.
        https://sketchucation.com/resources/plugin-store-download
          amihumi
          When I install a plugin that does not work, the plug-in has been installed and I can see the plugin file in the plugins folder, but when I reopen the program I have a load error window.
          The window reads:
          Error Loading File 1001bit_freeware.rb
          Error: # <Encoding :: UndefinedConversionError: "\ x9E" to UTF-8 in conversion from Windows-1255 to UTF-8>
          πŸ˜„ / Users / Hoodia Huminer / AppData / Roaming / SketchUp / SketchUp 2016 / SketchUp / Plugins / 1001bit_freeware.rb: 23: in exist? ' C: / Users / Hoodia Huminer / AppData / Roaming / SketchUp / SketchUp 2016 / SketchUp / Plugins / 1001bit_freeware.rb: 23: in <module: GCH_1001bit_load> '
          πŸ˜„ / Users / Hoodia Huminer / AppData / Roaming / SketchUp / SketchUp 2016 / SketchUp / Plugins / 1001bit_freeware.rb: 5: in <module: GCH_1001bit_free> ' C: / Users / Hoodia Huminer / AppData / Roaming / SketchUp / SketchUp 2016 / SketchUp / Plugins / 1001bit_freeware.rb: 3: in <top (required)> '
          In addition to this problem, you told me to install SketchUcationTools. I installed it and it does work, but when I choose a plugin that I want to install and I click install, the software does not respond and the plugin is not installed. Unlike the previous problem, here there is no window that appears and warns of a problem but there is no response at all to click "install".
