    Is there a way to make surface planar
    11 Posts 6 Posters 2.4k Views 6 Watching
      mwm5053
      This is a roof line that wasn't completely planer made from several different objects it intersected with. I couldn't get the lines to make a face so I used Sandbox/ From contours I got a face but lots of hidden geometry which makes it hard if not impossible to extrude of use the offset tool. So Is there a way to make surface planer without any hidden geometry?
      Component_60.skp
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • Bob JamesB Offline
        Bob James
        I suppose there are more elegant ways but:
        Select the edges, make them a group and drape them onto a flat plane?
        Or, if you have the Q Align plugin, select the edges and make them all the same height?
        The first way always works and automatically provides the surface.
          mwm5053
          Thanks to you both. Both methods worked thanks so much.
          2011 iMac
          V2 Twilight
            Flatten Vertices by Niall Campbell
            Tig has one too more complete! Drop Vertices but you must select only edges!
            • PixeroP Offline
              Pixero
              @sdmitch:
              Thanks for the great script snippet.
              Would it be possible to modify it so that it would work on a selection of several non connected surfaces and that it would clean them up at the same time. Now I must select each surface by hand which takes considerably longer.
              • sdmitchS Offline
                sdmitch
                @pixero said:
                @sdmitch:
                I would assume so. Are we talking about normally grouped surfaces that you want to able to select all and process them individually as you are currently doing one at a time?
                http://sdmitch.blogspot.com/
                  The "Flatten vertices" above makes that! 😉
                  Just use Clean Up after! 🤓
                  • PixeroP Offline
                    Pixero
                    @Pilou: That didn't work in my case.
                    @sdmitch: I've sent you an example file as a PM.
                      Without file that is difficult to test! 😄
                      • sdmitchS Offline
                        sdmitch
                        I don't have access to SU2017 at the moment but my guess is that, since this is part of a roof, it is sloped so draping or making all z's the same will not work but maybe this will help.
                        Open the group for edit and select all. Paste code snippet into the Ruby Console and press Enter.
                        @mod = Sketchup.active_model
                        @ent = @mod.active_entities
                        @sel = @mod.selection
                        @vue = @mod.active_view
                        vrts = @sel.grep(Sketchup;;Edge).map{|e|e.vertices}.flatten.uniq
                        pnts = vrts.map{|v|v.position}
                        plane = Geom.fit_plane_to_points pnts
                        pnts = vrts.map{|v|v.position.project_to_plane(plane)}
                        vecs = []; edgs = []
                        vrts.each_with_index{|v,i|vecs<<v.position.vector_to(pnts[i])}
                        @ent.transform_by_vectors(vrts,vecs)
                        @sel.grep(Sketchup;;Edge).each{|e| next unless e.faces[1];edgs<<e}
                        @ent.erase_entities(edgs.reverse)
                        • kenK Offline
                          ken
                          Well the way I make a surface a plane is to use the rotated rectangle, pick three points that should lay on the same plane. This makes a rectangle that is a least a flat plane to three of the points. Then I offset the rectangle until it covers the area I wish to cover, then intersect with model, and pesto, a flat plane. Note, if the flat plane does not connect to all the edges, you will need to move the plane to connect to all the other surfaces, or modify the surfaces that don't connect to the plane.
                          Ken
