    Ruby Observer Existence Check
    6 Posts 3 Posters 1.9k Views 3 Watching
    • H Offline
      hank
      Is there any way to check to see if an entity already has an observer attached to it?
      I am using:
      class MyInstanceObserver < Sketchup;;InstanceObserver
        def onChangeEntity(entity)
      	  #puts "onChangeEntity; #{entity}"
      and then
      my_openings = ent.grep(Sketchup;;ComponentInstance).find_all {|oi| oi.definition.name.include?('OPENING') }
        my_openings.each do |oi|
          next unless oi.valid?
        oi.add_observer(MyInstanceObserver.new)
      But would prefer not to blindly attached an observer always. This loop will have been run previously.
        How about doing it this way.
        Outside of any of your methods...
        @@obs = MyInstanceObserver.new() unless @@obs
        That only runs once and its reference can then be used thus:
        oi.remove_observer(@@obs) oi.add_observer(@@obs)
        Attempting to remove a non-existent observer does NOT raise an error.
        So in this way just one instance of the observer is only ever attached to an instance.
        • H Offline
          hank
          Thanks TIG. I though @@ was for classes???
          I got an "uninitialized class" error until changed @@obs to @obs
          Your solution worked perfect though!
            You usually set @@obs = nil inside a class [outside of any method].
            Then within one of that class's methods [like initialize()] you can set it to be a proper reference - but just the once.
            In a class it needs to be @@obs = ... to persist across instances of the class.
            A @obs = ... in a class only exists during that one instance of the class.
            In my example I set it only if it's not already set [i.e. it is nil].
            You can set @obs = ... within a module, outside of any of its methods and that then persists thereafter.
            Since I didn't have your whole code I guessed... πŸ˜•
            • H Offline
              hank
              Thanks TIG. Have not gotten very advanced with Classes etc. so just a simple module. Appreciate the explanation.
              • Dan RathbunD Offline
                Dan Rathbun
                This is true because, a module is an instance of class Module.
                The Class class is the direct child class of class Module. So classes inherit all of Module's functionality, and get a little bit of their own (ie, a few extra methods and the ability to have many instance copies of themselves, that can hold their own instance variable values.)
                I'm not here much anymore.
