Scrapbook scale bar...
The default scale bars don't match my drawing.
Is there an easy way to set this to the scale on my page?
Or is it better to just create a different scale bar for each scale I use (1:20, 1:50 and 1:100) and just keep them in the scrapbook?
And lastly, what scale is the standard scale bar set to?
What scale bar are you looking at? I only find one in site. It appears to scale to 1/2"=1' (Use a dimension on it and adjust the dimension scale until it agrees), which is not appropriate for a site plan.
Make your own scales and save them. Or fix the one they've got and save that. If you try just simply scaling it you may have stupid problems like wrapping text.
Register LoginAdvertisement
