    [Q] Scaling an Imported Image
    7 Posts 3 Posters 8.9k Views 3 Watching
    • Bob JamesB
      Bob James
      For many years when I've imported an image and needed to change its scale to make the length of a line on the image to a specific length, I added a line on the image to a desired length, grouped the line with the image, edited the group by tracing the added line with the Tape Measure Tool, entered the length I wanted it to be, hit return and a dialog box would pop up asking if I wanted to change the scale of the whole image. If I selected "Yes", then the whole image would be scaled to make the length the specified amount and, therefore, all the rest of the dimensions would also be correct.
      I had an occasion to do that yesterday and that process doesn't work anymore.
      Can anyone tell me how I can do it with SU2017?
      • PixeroP
        Pixero
        RubySketch Scale Tool.
        http://sketchucation.com/pluginstore?pauthor=aadbuild
        • BoxB
          They changed the default of the tape tool in 2017, tap ctrl to toggle the guide on or off to get the action you want.
          • Bob JamesB
            Bob James
            MANY thanks, Box πŸ‘ It's hard to figure the logic behind that change ❗
            Pixero: I'll take a look at the Rubysketch Scale Tool, but it will be hard to break a very old habit. 😎
            • PixeroP
              Pixero
              The great thing is that you can scale a selected object or image without rescaling the entire SU scene.
              • BoxB
                The Tape will resize within a group or component without affecting the rest of the model.
                • Bob JamesB
                  Bob James
                  That was true before the change to having to use ctrl. I have often built up a scene by building part of it and then bringing in a photo containing a dimensioned line drawing then scaling it to "real" size: the rest of the models in the scene were not affected by the rescaling of the picture.
