    T.V. Stand
    7 Posts 4 Posters 2.7k Views 4 Watching
    • tuna1957T
      tuna1957
      Messing about some more. T.V. / entertainment stand. Drawers sized to fit DVD's. If I can find the time would actually like to build this for myself. Might tweak details of the design some before it get's built.
      Posting two pic's , one rendered in Twilight , minor post pro inside Twilight. The other a raw SU image with a line overlay and some tweaking in Gimp.
      Pulled drawers out on the raw image to show I really did model most of the details on this one. Only thing I left out was the full extension drawer slides the piece would have in real world.
      • D
        davidheim1
        Good looking piece, good looking render. Thanks for sharing.
        Best,
        dh
        • tuna1957T
          tuna1957
          Thank's David.
          • D
            db11
            On such a nice piece β€” with dovetailed drawers β€” wouldn't undermount slides be a better option than (side-mount) full-extension?
            • tuna1957T
              tuna1957
              db11 , You have a valid point. Will need to research slides that are available now to see options. Last time I bought slides for a project was a good while ago. Most under mounts available then didn't have very high weight capacities. I'm sure the design will go through numerous revisions until I actually have the time to make it.
              • S
                slbaumgartner
                Undermounts are available today with significant load ratings (100lb/45kg and 150lb/68kg), so that shouldn't be a problem - e.g. Blum Tandem, Salice, and others. Be advised, though, that they require clearance under the drawer bottom which will affect the drawer height required to fit CD cases inside the drawer.
                • tuna1957T
                  tuna1957
                  slbaumgartner , thanks for the heads up about the drawer slides. I don't want to admit how many years it's been since I've really looked at what's available.
