    Ruby Sketchup Programmatic Union of Multiple items
    10 Posts 4 Posters 3.5k Views 4 Watching
    • H Offline
      hank
      Hello. If you want to union multiple solids programmatically, how would you do it? With the union tool (Tools > Solid Tools > Union [Pro Only]) you pick one solid, then another but can continue to pick solids, adding to the Union Result. Using #union(group) however, I am having trouble keeping a handle on the union result in order to continue adding to it.
      If I do
      union_result = group_a.union(group_b)
      I can't seem to refer to union_result when I try to run union again for subsequent objects.
      Here is the total picture that may provided more insight...
      Disclaimer: this seems like a dumb way to do this but, because when I loop through all my target groups, I need something to union the first one with, I am creating a small dummy group like so...
      mod = Sketchup.active_model
      ent = mod.active_entities
      # create a dummy object for initiating union
      dummy_face = ent.add_face([0,0,0],[1,0,0],[1,1,0],)
      dummy_group = ent.add_group(dummy_face)
      dummy_group.name = 'DUMMY GROUP'
      dummy_face.pushpull(1,true)
      Then here is the actual iterating (WARNING - BUG SPLATS!):
      ent.grep(Sketchup;;Group).each_with_index do |item, i|
      	next if item.name!='MY_TARGET_GROUPS'
      	if i <= 1 # first run so union with dummy
      		union_temp = item.union(dummy_group)
      		union_temp.name = 'TEMP_RESULT'
      	else # subsequent runs can union with prior union result
      		union_final = item.union(union_temp)
      		union_final.name = 'UNION_RESULT'
      I also tried using entities[-1] for the last created entity and that ALSO BUG SPLATS:
      union_final = item.union(ent[-1])
      Perhaps there is something I am misunderstanding about iterating that "clears" the variables created during each loop? Do I need a global or something using the @ designation?
      Also, instead of using a dummy object, perhaps I should just skip the first group - but then I would need a handle to be able to refer to it during the next iteration?
      Your thoughts would be appreciated.
      • Dan RathbunD Offline
        Dan Rathbun
        Yes other coders use dummy groups, but usually just push a cpoint into it, which can be easily removed later.
        Iterating collections. You cannot modify the same collection that you are iterating, ie changing the number of members. The iteration loses it's way, and members are either skipped, or referenced after they've been deleted. (We've said this so many time here, you'll likely get search hits on "iterate" etc.)
        So we usually make a copy of the collection, and iterate the copy. Also check each iterative reference for validity and loop next if it's no longer valid. Ie:
        next unless item.valid?
        I'm not here much anymore.
        • H Offline
          hank
          Perfect Dan - Thank you. That was a two for: next unless item.valid? will be so helpful too.
          BTW, I tried @variables and skipping the first element as shown below and it worked!
          	if i < 1
          		puts "skipping first iteration for item; #{item} | #{i}"
          		@first_one = item
          	elsif i == 1
          		@first_union = @first_one.union(item)
          		@subsequent_handle = @first_union
          	else
          		@result_union = @subsequent_handle.union(item)
          So the @variable was "remembered" as TIG explained to me here which seemed to be what I needed.
          Now I just have to streamline the iteration BEFORE the loop because this method uses an index that can't see the next if item.name!='MY_TARGET_GROUPS' check. If I have 10 groups and only 3 of them qualify, the index will be off and I might save the wrong @first_one. If I could get grep to do a Group check AND a name check, I could iterate with an accurate index. Can grep be passed multiple patterns in one call?
          • H Offline
            hank
            Dan, that is genius. Thank you.
            I think this
            g.name = 'MY_TARGET_GROUPS'
            needs to be changed to
            g.name == 'MY_TARGET_GROUPS'
            Right? It changed set all group names rather than testing for equivalence.
            Anyway, grep with a more complex block seems like such a more efficient way of getting objects than getting an array then looping it to test for certain properties, then looping THAT array to test for others, and so on... which is what I felt like I was doing before. This will be really helpful generally.
            And got it about the 2 spaces... Just didn't paste in from Dreamweaver cleanly but will do!
              Dan Rathbun
              grep() can be passed a block.
              OR, you can call another of the iterative filter methods from Enumerable.
              And read the Ruby core docs when you wish to know what a method can and cannot do.
              http://ruby-doc.org/core-2.2.4/Enumerable.html
              Enumerable is a mixin library module that is mixed into most all collection classes.
              Would something like this also work ?
              grps = ent.grep(Sketchup::Group).find_all {|g| g.name == 'MY_TARGET_GROUPS' }
              # check here to be sure grps is not empty
              @union = grps.shift # slice the first member from grps array
              grps.each do |item|
                @union = @union.union(item)
              # after the loop, refs in "grps" are all likely invalid;
              grps.clear
              P.S. - Ruby uses 2 space indents. There is NO coding language in the world that uses odd number of spaces in indents. (Really annoying.)
              S 1 Reply Last reply Reply Quote 0
                Dan Rathbun
                @hank said:
                I think this = needs to be changed to == ...
                Correct. My bad. I've fixed it in the above example.
                @hank said:
                Anyway, grep with a more complex block seems like such a more efficient way of getting objects than getting an array ...
                grep always first creates an array result from the pattern argument.
                If you read the description of the method in the docs, it is quite clear there will be a two stage operation if a block is used with grep. The drawback is that the block will process ALL the members returned by the pattern, and push the result of the block into the output array. This will not be a problem if you are not going to use the output array any further. (Ie, the output array might be a series of valid group objects [that passed the name property check,] and false references for any group that did not.)
                The most important part of grep'ing with a class identifier, is that it is extremely fast at filtering out any other item of other classes (that are not subclasses.)
                More specifically, text comparison in Ruby is slow, whilst class identity comparison is fast.
                @hank said:
                ... then looping it to test for certain properties, then looping THAT array to test for others, and so on... which is what I felt like I was doing before.
                It is not a big deal to do that once as I did in the above example, using grep to get all groups, then filtering out only those with a certain name.
                But, yes you can do compound conditional tests within iterator blocks:
                name_prefix = "MY_TARGET_GROUPS"
                starts_with = /\A#{name_prefix}/
                grps.each {|g|
                  if g.name =~ starts_with && g.material.name = "Green"
                    # Do something with matching group instance
                  else
                    # Do something else
                • H Offline
                  hank
                  Thanks Dan. Feelin' the power of grep!
                    Sklik Rab @Dan Rathbun
                    @Dan-Rathbun
                    How to check if @union become nil?
                    TIGT Dan RathbunD 2 Replies Last reply Reply Quote 0
                      TIG Moderator @Sklik Rab
                      @Sklik-Rab
                      If
                      @union
                      is an array use
                      if ! @union[0]...
                      To see if it has any elements left ?
                        Dan Rathbun @Sklik Rab
                        @Sklik-Rab said in Ruby Sketchup Programmatic Union of Multiple items:
                        @Dan-Rathbun
                        To check if the reference points at nil, you can use:
                        @union.nil? which is inherited by Array from Object#nil?
                        To check if the array is empty, you can use:
                        @union.empty?
