    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Please help!!! -- Projections and Guide Tools
    extensions
    3 Posts 3 Posters 1.3k Views 3 Watching
      corileigh
      Hello! I have encountered problem that I hope I might be able to overcome that is really difficult for me to describe but I will try my best. So the space that I am designing will use anamorphic projection on multiple surfaces within the space. In order for me to properly achieve this, I need to be able to take the graphic that I want and then project it onto all of those surfaces (which I'm not entirely sure is possible at this point). I found an extension that I'd love to get because I think it has what I need, called projections and guide tools by D. Burr, but for some reason, it will not allow me to download the extension.
      That being said, what I need out of the tool is for it to "drape" or project the image in a cone-like array from one specific vantage point. If you look up anamorphic art, this might make more sense than what I am trying to describe. I can not seem to find any tool to help me get the desired effect.
      The drape tool is the closest thing I've found to what I need, but even then it only drapes it with all lines parallel to each other and not in a cone-like fashion. I know this is a really ridiculous request, but I'm just trying to see if it's even possible, or how I can download that extension. Thank you in advance!
      • gillesG Offline
        gilles
        you could try Photomatch ( File/import/use as/new Photomatch ).
          See this entire thread! πŸ˜‰
