    How to create a road from centerlines?
    7 Posts 2 Posters 1.8k Views 2 Watching
      troyhome
      I swear I remember a plugin that would do this, but can't recall what it would be...
      I have an urban plan with road centerlines. I'd love to select them all and turn them into roads.. basically offset the web of centerlines about 10' on either side of the centerline, create a surface, and boom!
      Any advice??
      IOviz.com
      SU Pro 2024 PC
        See thomthom city street Generator road (?)....
        I come back with the address
        http://sketchucation.com/forums/viewtopic.php?f=314%26amp;t=19493 πŸ˜‰
        http://sketchucation.com/forums/download/file.php?id=28088&t=1
        Double line by Didier Bur (but segment one by one)
        Double line plus by Sdmitch
        http://sketchucation.com/forums/download/file.php?id=142798
          troyhome
          Thank you, Pilou! I feel like there was another one where I could make a rectangle, draw in some lines to make it look like a window, then run this plugin and voila! Very similar to ThomThom's city generator. I'll look into these options meanwhile πŸ˜„
          IOviz.com
          SU Pro 2024 PC
            Lattice Maker by Tig (but "Flat plane" )
            Shape Bender by Chris Fullmer! πŸ˜‰
            Vali Instant road ($)
            Followme & Rotate by wikii (without rotate & Curve by curve ! πŸ˜‰
            With the one above Perpendicular tool by Chris Fullmer can help!
              Yes it's Lattice Maker! πŸ˜‰
                troyhome
                that's it!!! thank you!!
                IOviz.com
                SU Pro 2024 PC
                  And when you curvate it with Fredo Scale! πŸ˜„
                  (random rectangles are made with the tricky Protrude by Jim)
