    Ruby selection
    2 Posts 2 Posters 655 Views 2 Watching
    • Y Offline
      yalhassanpro
      Hello forum,
      I have a model which consists of faces and unconnected lines. How do I select the lines only using Ruby? I have attached an image file.
        First we set up some references.
        model = Sketchup.active_model ss = model.selection
        Then depending on how you want to 'start' off your plugin...
        edges = model.active_entities.grep(Sketchup::Edge)
        An array of all edges in the active context***
        OR
        edges = ss.grep(Sketchup::Edge)
        An array of all edges in the current selection.***
        Now resolve the selection:
        ss.clear ss.add(edges)
        ***The 'rep' finds all edges, including those bordering faces.
        So if you want to select just those edges without faces then you can extend the 'grep' code thus
        ... .grep(Sketchup::Edge).find_all{|e| e.faces.length == 0 }
        The array 'edges' then just lists those edges without faces...
