    Subtraction with Intersect Method
    5 Posts 3 Posters 2.1k Views 3 Watching
    • medeekM
      medeek
      Has anyone ever tried using the intersect method to perform boolean subtraction of two solids?
      http://ruby.sketchup.com/Sketchup/ComponentInstance.html#intersect-instance_method
      I really need to do boolean subtraction on some new modules I'm working on but I want to make sure I'm compatible with SketchUp Make and not force the user to go to Pro if I don't have to.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Dan RathbunD
        Dan Rathbun
        All Solid Tools boolean API methods are Pro only. (This used to be indicated in the docs.)
        I'm not here much anymore.
        • medeekM
          medeek
          I have to intersecting cubes in my model. I then run this ruby code:
          group1 = entities[0]
          group2 = entities[1]
          trans1 = group1.transformation
          trans2 = group2.transformation
          group1.intersect_with(false, trans2, group1, trans1, false, group2)
          Which then gives the following error:
          Error; #<NoMethodError; undefined method `intersect_with' for #<Sketchup;;Group;0x0000000dd92350>>
          <main>;in `<main>'
          SketchUp;1;in `eval'
          design.medeek.com
          • sdmitchS
            sdmitch
            > <main>;in `<main>'
            .intersect_with needs the group.entities
            group1.entities.intersect_with(false, trans1, group1.entities, trans1, false, group2)
            http://sdmitch.blogspot.com/
            • medeekM
              medeek
              Got it. Thank-you Sdmitch. As always your guidance with the syntax is impeccable. Even after a year I'm still feel like a bull in a china shop
              I'm still a bit of a ways away from a boolean subtraction but at least I have something to work with now.
              design.medeek.com
