Subtraction with Intersect Method
5 Posts 3 Posters 1.7k Views 3 Watching
    medeek
    Has anyone ever tried using the intersect method to perform boolean subtraction of two solids?
    Class: Sketchup::ComponentInstance
    The Sketchup::ComponentInstance class is used to represent component instances of a component definition or components that have been dragged from the Component Browser and placed (thus, instanced) within the Model.
    SketchUp Ruby API Documentation (ruby.sketchup.com)
    I really need to do boolean subtraction on some new modules I'm working on but I want to make sure I'm compatible with SketchUp Make and not force the user to go to Pro if I don't have to.
    Nathaniel P. Wilkerson PE
    Medeek Engineering Inc
    design.medeek.com
      Dan Rathbun
      All Solid Tools boolean API methods are Pro only. (This used to be indicated in the docs.)
      I'm not here much anymore.
        medeek
        I have to intersecting cubes in my model. I then run this ruby code:
        group1 = entities[0]
        group2 = entities[1]
        trans1 = group1.transformation
        trans2 = group2.transformation
        group1.intersect_with(false, trans2, group1, trans1, false, group2)
        Which then gives the following error:
        Error; #<NoMethodError; undefined method `intersect_with' for #<Sketchup;;Group;0x0000000dd92350>>
        <main>;in `<main>'
        SketchUp;1;in `eval'
        design.medeek.com
          sdmitch
          > <main>;in `<main>'
          .intersect_with needs the group.entities
          group1.entities.intersect_with(false, trans1, group1.entities, trans1, false, group2)
          http://sdmitch.blogspot.com/
            medeek
            Got it. Thank-you Sdmitch. As always your guidance with the syntax is impeccable. Even after a year I'm still feel like a bull in a china shop
            I'm still a bit of a ways away from a boolean subtraction but at least I have something to work with now.
            design.medeek.com
