    Ambient Occlusion Plugin problems.
    2 Posts 2 Posters 553 Views 2 Watching
    • C
      CalypsoArt
      I tried out the Ambient Occlusion Plugin. (Seems to do what Visulizer did.) This level of render works great for my work. I have Podium and had Twilight, but those have learning curves and resulting render times that are just to long for my work flow. That said, with Ambient Occlusion I can only do a viewport render. Selecting the "window" render--which includes more option--gives me a blank window. The longest threads on their forum are about this problem, which so far has no solution. Anyone here try this plugin, have the same problem, found work around? As SU plugins go, $89 is not cheap. Even more so for a plugin that half works.
      • F
        fluid
        The blank window issue has been solved in the latest version of AmbientOcclusion, you can get it here
