    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Version 2.4.6 - 10.22.2021
      • Added two additional advanced options for in-wall columns: Top Plt. Cut, Btm Plt. Cut.
      • Added two additional parameters into the Columns tab of the global settings.
      • Fixed a critical bug with the wall copy tool that was created with the prior update.
      • Added error checking code into the rectangular wall edit menu for sheathing, cladding, and gypsum materials.
      • Added error checking code into the window edit menu for the shutter material.
      http://design.medeek.com/resources/wallplugin/images2/wall_su586_800.jpg
      With the in-wall columns I've also changed the draw and edit tool so that the columns can be drawn at the end of the walls, there is no longer the one-stud limitation, not even sure why I added that in originally.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.4.7 - 10.24.2021
        • Fixed a bug with shed walls for the following end configurations: Inside Corner, Inset Inside Corner.
        http://design.medeek.com/resources/wallplugin/images2/wall_su587_800.jpg
        This fix should resolve the issues we were seeing with the shed wall. I probably missed these bug(s) initially because the inside corner with a shed wall is not very common and sometimes I don't test every possible permutation even though I should.
        I may need to go back into the gable and hip wall modules and test them a bit further.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.4.7b - 10.25.2021
          • Added the following additional Wide Flange (W) beams to the beam module: W10X22, W10X26, W10X30, W10X33, W10X39, W10X45, W12X26, W12X30, W12X35, W12X40.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.4.8 - 10.30.2021
            • Added an end cripples option for all window types.
            http://design.medeek.com/resources/wallplugin/images2/wall_su588_800.jpg
            I will probably also need to add in this option for doors and garage doors.
            !!! WARNING !!!
            This update will require deleting and recreating any window presets. This update will not affect any other preset types (ie. wall, door, garage door etc...)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.4.9 - 10.31.2021
              • Added an end cripples option for all man doors.
              • Added an end cripples option for all garage doors.
              • Fixed a bug with exterior trim for arched garage doors when the "trim union" option is enabled.
              http://design.medeek.com/resources/wallplugin/images2/wall_su589_800.jpg
              http://design.medeek.com/resources/wallplugin/images2/wall_su590_800.jpg
              !!! WARNING !!!
              This update will require deleting and recreating any door and garage door presets. This update will not affect any other preset types (ie. wall, window etc…)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.5.0 - 11.06.2021
                • Added a rainscreen option for rectangular walls (vertical furring strips).
                http://design.medeek.com/resources/wallplugin/images2/wall_su591_800.jpg
                !!! WARNING !!!
                This update will require deleting and recreating any rectangular wall presets. This update will not affect any other preset types (ie. gable wall, shed wall, hip wall, door, window etc…)
                This feature has been requested multiple times lately so I thought I might try and get a rudimentary rainscreen feature put together. Note that the current rainscreen module is fairly simple and does not trim around openings. If you want the furring strips to line up with the studs you can set the offset value to 1/2 of the stud spacing (or any other value for a different alignment).
                I consider this feature more representational at this point but please give me additional feedback with regards to future improvements or additional options/requirements.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.5.1 - 11.14.2021
                  • Added a horizontal rainscreen option for rectangular walls (horizontal furring/girt boards).
                  • Added an option for top and bottom furring/girt boards for horizontal rainscreens.
                  http://design.medeek.com/resources/wallplugin/images2/wall_su592_800.jpg
                  If you set the top or bottom sizes to "zero - 0.0" then it will eliminate that respective option.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    In recognition of the overwhelming support I have received from the SketchUp community during 2021 I will be immediately offering 35% off of the mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS21 . (promotion ends Dec. 1, 2021).
                    This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
                    https://aws1.discourse-cdn.com/sketchup/original/3X/1/7/171932bd5c293a4396c7d2cd8e160a41cf227ab8.jpeg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.5.2 - 11.15.2021
                      • Fixed a bug with exterior trim (corners) for shed walls.
                      • Fixed a bug with rectangular wall presets.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.5.3 - 11.23.2021
                        • Added a Custom Column Library/Manager in the Columns tab of the Global Settings.
                        • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) columns.
                        • Created the Medeek Wall API: wall_regen
                        • Enabled an additional wall justification option for all wall types: Sheathing.
                        http://design.medeek.com/resources/wallplugin/images2/wall_su593_800.jpg
                        http://design.medeek.com/resources/wallplugin/images2/wall_su594_800.jpg
                        *Note: Just a reminder that the Alt key is the hotkey for toggling the wall justification.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Note: To call the wall_regen method:
                          Medeek_Engineering_Inc_Extensions;;MedeekWallPlugin;;Wall;;MedeekMethods.wall_regen entity
                          where the entity is the Medeek wall group.
                          The column update required modifying at least 10 files and took about five days of concerted effort, some of it quite tedious and I will say boring, but yeah, it is always worth it. Basically an entire rewrite of the in-wall column module, a lot of the code under the hood was reviewed and updated to bring it up to speed with the highly efficient beam module. Now all of the menus are HTML as well.
                          The addition of the API took all of 15 minutes to add.
                          The wall justification was only about another 1.5 hours of work.
                          Mostly it was me deciding whether it would muddy the waters too much to go from three options to four (front, center back → front, center, back, sheathing). You will notice that when you use the draw wall tool now it will show a small text near the wall length dimension letting you know which justification mode that you are in. The placement and the size of this specific text may yet require some fine tuning, I want that information to be available to the user but I don’t want it to be so obtrusive that it is annoyingly so. Feedback required…
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.5.4 - 11.26.2021
                            • Improved the organization of the HTML draw and edit menus for rectangular walls.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.5.5 - 11.27.2021
                              • Updated the SSW draw menu with an HTML menu.
                              http://design.medeek.com/resources/wallplugin/images2/wall_su595_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Just a reminder that the Thanksgiving promotion (Black Friday/Cyber Monday) is still ongoing and will be active until Dec. 1st:
                                http://design.medeek.com/ads/GIVETHANKS21_BANNER_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.5.6 - 12.05.2021
                                  • Added a "Posts" tab into the Global Settings.
                                  • Added a Custom Post Library/Manager in the Posts tab of the Global Settings.
                                  • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) posts.
                                  http://design.medeek.com/resources/wallplugin/images2/wall_su596_800.jpg
                                  This should complete the custom libraries for beams, headers, column and posts.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Tutorial 24 - Custom Libraries (17:49 min.)
                                    A brief introduction and explanation of the custom header, beam, column and post libraries within the global settings.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.5.7 - 12.10.2021
                                      • Enabled opening and closing of single hung and slider windows.
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/c/c/cce895f137c0b1e824b93f45076bbd004f2ed2d3.gif
                                      From a design and rendering standpoint I'm not really sure how useful this feature is but it stands to reason that if you can open the doors and garage doors you should also be able to open the windows.
                                      I have not enabled this feature yet for casement style windows.
                                      This feature was added per customer request.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.5.7b - 12.10.2021
                                        • Enabled opening and closing of casement windows.
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/2/d/2daf1a18c630de79afb61c48d896f05f7fecc3c3.gif
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.5.8 - 12.11.2021
                                          • Added awning, fixed-awning and awning-fixed windows to the window module.
                                          • Enabled opening and closing for all awning type windows.
                                          http://design.medeek.com/resources/wallplugin/images2/OPEN_WINDOWS3.gif
                                          The size ratio of the fixed to awning windows are 3:1. I currently don't have a way to customize this size ratio but I will be giving it some additional thought.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.5.9 - 12.12.2021
                                            • Fixed a minor bug in the shearwall draw and edit menus.
                                            • Enabled shearwall panel and fastener callouts/labels.
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su597_800.jpg
                                            This additional annotation can be toggled on and off with the Framing Callout option in the General tab of the Global Settings. Eventually I will probably setup a separate callout option in the Shearwall tab of the Global Settings so control can be a bit more granular.
                                            The bug in the menus was a simple typo with the nail size (10d).
                                            design.medeek.com
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 80
                                            • 81
                                            • 58 / 81
