    Enscape for Sketchup
    extensions
    79 Posts 23 Posters 65.3k Views 23 Watching
    • jenujacobJ
      jenujacob
      Hi guys,
      Enscape released their alpha version for Sketchup. Check it out here
      It works with SU2017 only....
      I for one cant seem to make it work though.
      A brief overview of the app by the folks at Show it Better....
      Error 404 (Not Found)!!1
      (m.youtube.com)
      • soloS
        solo
        Installing the .rbz crashes SU everytime.
        http://www.solos-art.com
          Same for me! ๐Ÿ˜ฎ
          • jenujacobJ
            jenujacob
            I installed it fine. But for me the problem is when i start the application from sketchup itself... it gives me the bugsplat! Well.. still alpha so i believe they might fox these issues soon enough!
            This looks like a serious and affordable contender to the likes of the overpriced lumion etc...
            • ShowitbetterS
              Showitbetter
              Hi guys! As you said, since it is the alpha version they are still quite a few bugs. I have been talking to the guys at Enscape and they are trying their best to fix this for the official release, so it really helps that you post these issues.
              On the other hand, I had the some problem when installing it, what worked for me was closing sketchup and opening again but choosing a different graphics card. I had the default built in one for SkP and when I chose the other one Enscape was good.
              Tell me if this works for you guys, and thanks for sharing the video ๐Ÿ˜„
              • soloS
                solo
                Like I said on FB, I have a Titan card and still it crashed, twice. I'm very interested in this as it fills a gap between Lumion and LumenRT (LumenRT has seemed to go into hibernation after Bentley acquired 'em)
                • jenujacobJ
                  jenujacob
                  @showitbetter said:
                  ......so it really helps that you post these issues.
                  But where? Is there an official forum for the sketchup version?
                  • ShowitbetterS
                    Showitbetter
                    I am sorry to hear that it didnยดt work Peter, I will let the guys at Enscape know about this, you are not the first one. We have programed releasing videos with each new feature and a how to install video next week.
                    I am going to check into it if there are any other possible ways around this issue, and I will be letting you know. It really is an awesome tool.
                    I will be updating you
                    • ShowitbetterS
                      Showitbetter
                      There is not an official forum (not that I know of). But I am sure that me and the guys at Enscape are constantly checking the feedback on the video I released and hopefully to Adamยดs winning with sketchup review.
                      For now if you post it here or on the videos I will see it and pass it on to the team at enscape.
                      • EarthMoverE
                        EarthMover
                        I've been doing a bit of testing and am really impressed thus far. Is it completely revolutionary? No. But, the integration into Sketchup and ease of use will really pull in some of the market. The VR support and panoramas are also a plus. It's upside being it's Sketchup integration, is also it's downside as it's very limited to what Sketchup can support. I don't honestly think Enscape will succeed unless it can figure out proxy support. If they can make it work with Skatter and allow for high poly proxy rendering via proxy, they will win over a lot of users. Visually, the GI and AA is amazing. I think up there with the best of them.
                        Bugs that I've found are with hidden geometry and layers not turning off in Enscape. Quad based texture mapping is not transferring. Also faceme components aren't moving in realtime.
                        Here are a bunch of my recent test renders to showcase a little of what it can do. These are literally just opening my old scenes and exporting out screenshots. I've done nothing else. I'd like to set up a scene full with plants and see how it does. I did test it on a scene with 3.5 million polys and it did fine. It just took a while to actually start up, but then everything moved around flawlessly. Overall, I would describe Enscape renders as simply "clean". Good color, good crisp lines
                        I also did a review here that goes through the UI and how to produce and animation, etc. - https://www.youtube.com/watch?v=vN1HIwzPv2M
                        Content Creator at Skapeup
                          Do you know if a free version (limited of course) will be existing ?
                          • ntxdaveN
                            ntxdave
                            @EarthMover - Thank you for a very informative video about Enscape. The part about Wrap-R was also very informative but I currently do not use SubD but I did learn a lot from your video on both topics. ๐Ÿ‘
                            I wish the trial was for longer than 14 days (especially since it is still in Alpha) but I will give it a try.
                            Press F1...thank me later
                            • soloS
                              solo
                              I agree.
                              • jenujacobJ
                                jenujacob
                                I am expecting them to come out with new alpha versions each of 14 day trial periods till they reach release version!
                                Enscape need to make their presence felt here at sketchucation (afterall this is a fairly large community).. somebody invite them over here already!!!
                                • ntxdaveN
                                  ntxdave
                                  Well, I just had to give it a try ๐Ÿ˜
                                  Here is an image and a movie I created with VERY LITTLE effort:
                                  Test Render
                                  and here is the movie:
                                  You can only imagine what this tool could look like when it moves on the next stages.
                                  • The render is almost instantaneous
                                  • Making my equipment materials look like metals was so easy thanks to the tips in @EarthMover's video
                                  • Imagine if you could generate an animation with Fredo's Animator plugin and include it
                                  • Would love to be able to generate the exe and see how that works
                                  • Would love to be able to view the Enscape version of a model directly on a web page
                                  • Would like to control the environment a little more (more options than in the current alpha
                                  I could go on with more "wish list" items but IMHO this is amazing for an alpha. In particular, the ease of use and the general quality of the output is amazing. As @EarthMover said in his video, if you had additional stuff available like in some of the competitive products, it would (and maybe already is) a no-brainer.
                                  • ntxdaveN
                                    ntxdave
                                    Still more rendered images:
                                    External Site Views
                                    Tunnel Equipment Views
                                    Support Equipment Views
                                    • jenujacobJ
                                      jenujacob
                                      @jenujacob said:
                                      Hi guys,
                                      Finally was able to make it work.... jusat had to update the display drivers!!!! ๐Ÿ˜† ๐Ÿ‘
                                      • soloS
                                        solo
                                        @jenujacob said:
                                        @jenujacob said:
                                        Hi guys,
                                        I updated my drivers on Thursday to the newest ones and still it crashes.
                                        • ntxdaveN
                                          ntxdave
                                          Hope you guys get it working. I think you are going to like it. Building renders and movies go really fast.
                                          • jenujacobJ
                                            jenujacob
                                            I updated my windows OS along side.... dont know if that helped my case though!! Hope u get it installed pete! I am sure u will enjoy using it as much as i do! Hope to put out some renders and a video and try and win that competition!!! ๐Ÿ’š
                                            • 1 / 4
