    Dynamic Component rotation issue
    2 Posts 2 Posters 6.8k Views 2 Watching
    • dereiD
      derei
      I tried to make an interactive rotating DC, but for some strange reason it seems to rotate around world axis, not local. The component is made in SU2017
      Please check the arm attached. When clicked on it, should lift the arm up, then second click should position it back. Instead, first click rotates the arm 90 degrees on horizontal plane, then the next clicks will swing it up/down.
      Interesting fact, when I enclose the arm component in another outer component and I align axes inside, it performs correctly. This leads me to think that the component revolves around its parent axis, not local. For sure I would need some clarifications here. Is it anything changed lately in SU?
      Thank you very much.
      Arm.skp
      DESIGNER AND ARTIST DEREI.UK
      • TNTDAVIDT
        TNTDAVID
        Hello derei,
        Try thi:
        http://i.imgur.com/2YRApAn.jpg
        Arm Bis.skp
        See you soon
        David
