    [Plugin]Make Unique Plus
    extensions
    5 Posts 4 Posters 4.9k Views 4 Watching
    • yorik1984Y Offline
      yorik1984
      Hello everybody!
      I represent my small plugin for big modeling improvement!
      Thanks for honoluludesktop
      and his plugin Make Unique Selected Components
      ABOUT
      Plugin for Sketchup 8 Pro or above for making unique selected components depend of nesting levels.
      USING
      Right click on component and/or group, or selected components and groups, and "Make Unique Plus". It has two submenus:
      1. Only parent level - This will make unique all selected components without their nested levels. Any report or message are absent.
      2. Choose nested level... - This will make unique all selected components and their nested selected levels components.
      You can choose nested level from list. 2 level is parent. Report has three understandable options:
      • Off
        • Short in messagebox
        • Full in console
      NOTE. In SketchUp version 2014 or above console will be open automatically if it not opened yet. In other case you must open via "Window > Ruby Console".
      INSTALLING
      Install from .rbz or source code on GitHub
      TODO
      - Make unique components in any sublevel and make unique all parent components thru upward to model parent level
      make_unique_plus_v1.0.rbz
      • pbacotP Offline
        Honolulu Desktop's legacy continues.
        Thanks for this Yorik. I've been using another plugin, but this is a needed function. Saves a lot of trouble.
        • PixeroP Offline
          Pixero
          Thanks.
            yorik1984
            I receive message from user for more improvement:
            • Make unique components in any sublevel and make unique all parent components thru upward to model parent level
              To be continued... 😄
              setmoveisplanejados
              Hi yorik1984!
              First of all, thank you very much for the plugin! It helps a lot!
              The only time I have encountered a problem was with a test of a "worst case scenario" of mine (I'm developing a spreadsheet to use the data from sketchup).
              I tried with two times of "component groups", making them as a new component and the other time using Component Groups. Your plugin worker just as expected when I make new components, but it failed when I use groups 😞
              Make Unique Plus Test (Using Groups)
