    How To Get All The Components With The Same XYZ Axis
    3 Posts 2 Posters 7.0k Views 2 Watching
    • S
      SketchUcationKid
      hi everybody!
      I created a component with composed by 2 components. when I select the main component, I can see the XYZ axis of the subcomponents. for instance, for the component A, X=-1.9 / Y=0 / Z=0. but, when I select this subcomponent A, inside its atributes, X=0 / Y=-1.9 / Z=0. in other words, X becomes Y and Y becomes X.
      1. why does it happen?
      2. how to fix it?**
      thanks in advance.
      • TNTDAVIDT
        TNTDAVID
        Hello,
        Can you attach the file?
        cordially
        David
        • S
          SketchUcationKid
          hello @TNTDAVID. thanks for your reply. I solved the problem by exploding the component and rebuilding it again. 😉
