    Ruby saveas .XLSM, format code
    5 Posts 3 Posters 1.9k Views 3 Watching
    • D
      davesexcel
      I thought 52 was the code to save as an .xlsm file, but I get an UndefinedConversionError.
      workbook.SaveAs("C;\TestFolder\TestAddImage.xlsm",52)
      • S
        slbaumgartner
        Did you accidentally post in the wrong forum? There is no workbook object and no SaveAs method in SketchUp or in native Ruby...
        • Dan RathbunD
          Dan Rathbun
          No Steve, he's fine. He uses the Ruby standard WIN32OLE library to connect SketchUp with Excel workbooks.
          This library basically exposes the VBA object model of Excel to Ruby. SO he's attempting to make a OLE call to Excel's VBA "SaveAs" method.
          This is the entry page for the Excel VBA object model:
          https://msdn.microsoft.com/en-us/library/ff194068.aspx
          This page coves the Workbook object:
          https://msdn.microsoft.com/en-us/library/ff835568.aspx
          This page is for the Workbook.SaveAs method:
          https://msdn.microsoft.com/en-us/library/ff841185.aspx
          This page is for the XlFileFormat Enumeration, whose members are to be used in the 2nd argument to Workbook.SaveAs:
          https://msdn.microsoft.com/en-us/library/ff198017.aspx
          The XLSM format came out in 2007.
          But has it been superseded in newer Office versions ?
          List of Microsoft Office filename extensions:
          https://en.wikipedia.org/wiki/List_of_Microsoft_Office_filename_extensions
          Office Open XML (Microsoft invented standard, and copyright holder.)
          https://en.wikipedia.org/wiki/Office_Open_XML
          Not to be confused with:
          OpenOffice.org XML (obsolete, superseded by OpenDocument):
          https://en.wikipedia.org/wiki/OpenOffice.org_XML
          OpenDocument (The FREE international standard):
          https://en.wikipedia.org/wiki/OpenDocument
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            As a general rule, try to use the interface's constants rather than direct use of integers. (The integers could change in the future and break your code.)
            Microsoft forums:
            Excel for Developers:
            https://social.msdn.microsoft.com/Forums/vstudio/en-US/home?forum=exceldev%26amp;filter=alltypes%26amp;sort=lastpostdesc
            Open XML Format SDK
            https://social.msdn.microsoft.com/Forums/vstudio/en-US/home?forum=oxmlsdk%26amp;filter=alltypes%26amp;sort=lastpostdesc
            • Dan RathbunD
              Dan Rathbun
              I did a search in the MS Excel Dev forum on "+SaveAs +xlsm +UndefinedConversionError", and got 947 hits. (You can browse those yourself.)
              https://social.msdn.microsoft.com/Forums/vstudio/en-US/home?forum=exceldev%26amp;filter=alltypes%26amp;brandIgnore=True%26amp;sort=relevancedesc%26amp;filter=alltypes%26amp;searchTerm=%2BSaveAs+%2Bxlsm+%2BUndefinedConversionError
              At this point I would double-check that any macros in the Workbook do not have errors, that could give the file export routine issues.
