Ruby saveas .XLSM, format code
I thought 52 was the code to save as an .xlsm file, but I get an UndefinedConversionError.
workbook.SaveAs("C;\TestFolder\TestAddImage.xlsm",52) -
Did you accidentally post in the wrong forum? There is no workbook object and no SaveAs method in SketchUp or in native Ruby...
No Steve, he's fine. He uses the Ruby standard
WIN32OLElibrary to connect SketchUp with Excel workbooks.This library basically exposes the VBA object model of Excel to Ruby. SO he's attempting to make a OLE call to Excel's VBA "SaveAs" method.
This is the entry page for the Excel VBA object model:
https://msdn.microsoft.com/en-us/library/ff194068.aspxThis page coves the
Workbookobject:
https://msdn.microsoft.com/en-us/library/ff835568.aspxThis page is for the
Workbook.SaveAsmethod:
https://msdn.microsoft.com/en-us/library/ff841185.aspxThis page is for the
XlFileFormatEnumeration, whose members are to be used in the 2nd argument toWorkbook.SaveAs:
https://msdn.microsoft.com/en-us/library/ff198017.aspxThe XLSM format came out in 2007.
But has it been superseded in newer Office versions ?List of Microsoft Office filename extensions:
https://en.wikipedia.org/wiki/List_of_Microsoft_Office_filename_extensionsOffice Open XML (Microsoft invented standard, and copyright holder.)
https://en.wikipedia.org/wiki/Office_Open_XML
Not to be confused with:
OpenOffice.org XML (obsolete, superseded by OpenDocument):
https://en.wikipedia.org/wiki/OpenOffice.org_XMLOpenDocument (The FREE international standard):
https://en.wikipedia.org/wiki/OpenDocument -
> workbook.SaveAs("C;\TestFolder\TestAddImage.xlsm",52) >As a general rule, try to use the interface's constants rather than direct use of integers. (The integers could change in the future and break your code.)
Microsoft forums:
Excel for Developers:
https://social.msdn.microsoft.com/Forums/vstudio/en-US/home?forum=exceldev%26amp;filter=alltypes%26amp;sort=lastpostdescOpen XML Format SDK
https://social.msdn.microsoft.com/Forums/vstudio/en-US/home?forum=oxmlsdk%26amp;filter=alltypes%26amp;sort=lastpostdesc -
I did a search in the MS Excel Dev forum on "+SaveAs +xlsm +UndefinedConversionError", and got 947 hits. (You can browse those yourself.)
At this point I would double-check that any macros in the Workbook do not have errors, that could give the file export routine issues.
