    How to use FIND() in an IF() statement
    6 Posts 3 Posters 7.9k Views 3 Watching
    • H
      hank
      I'd like to be able to hide a group within a component based on the value of a text list variable (OPENING!TYPE) users select.
      Here is the IF clause I am using for the groups "Hidden" attribute:
      =IF(find("SINGLE",OPENING!TYPE),FALSE,TRUE)
      Which says "If the string "SINGLE" is found in the attribute value for "OPENING!TYPE", return FALSE making the group not hidden, otherwise return TRUE making the group hidden.
      The problem is that FIND() returns a number for where it found the search string. That is fine for when it successfully finds the search string because any positive number evaluates to true. BUT when it does not find it, it returns something like
      Not found; SINGLE
      Which does not evaluate to FALSE.
      So, how can I use FIND() to return TRUE or 1 if it finds the search string and FALSE or 0 when it does not?
      Thank you.
      • J
        Jim
        Not tested, but maybe:
        =IF(find("SINGLE",OPENING!TYPE)>0,FALSE,TRUE)
        • P
          pcmoor
          find needs to return a value, a position. so if if there is no match it fails. Since there is no error catch procedure, it is not possible to
          IF(find("SINGLE",OPENING!TYPE)>0,FALSE,TRUE) unless "SINGLE" exists, can only be true or an error
          • H
            hank
            Well that stinks. Is there any way to test for an error. Will Jim's solution work?
            • J
              Jim
              You could use LEFT and EXACT.
              =EXACT(LEFT(OPENING!TYPE, 6), "SINGLE")
              or a simple IF
              =IF(LEFT(OPENING!TYPE, 6) = "SINGLE", TRUE, FALSE)
              or maybe even
              =IF(OPENING!TYPE = "SINGLE", TRUE, FALSE)
              • H
                hank
                Thank You Jim!
                So how about if I wanted to find out if the string "SINGLE" exists anywhere in the string?
