    Tensile tent form finder
    8 Posts 5 Posters 1.6k Views 5 Watching
    • E Offline
      endpoint
      Hi all,
      For some time I am looking for a plugin that accurately forms a tensile tent structure form.
      There is already the Soap Bubble plugin that works for simple tent forms.
      There also is a plugin that you can download form http://de.sergeferrari.com/serge-ferrari-sketch-3/ The problem is that it doesn't work with the newer SU versions. Is there somebody in this community that could take a look at the code of the script and do some recoding/debugging so that this plugin also can be used in the newer versions.
      Your efforts will be highly appreciated.
      Thanks in advance,
      J-P
      • sdmitchS Offline
        sdmitch
        @endpoint said:
        Hi all,
        Thanks in advance,
        J-P
        Sorry but the main code is scrambled and only the creator will be able to modify it.
        http://sdmitch.blogspot.com/
        • gillesG Offline
          gilles
          @endpoint said:
          Hi all,
          Thanks in advance,
          J-P
          May be you could send a mail to Ferrari asking him if could update is plugin or share the code…
          • ntxdaveN Offline
            ntxdave
            Have you looked Curviloft? You can do pretty much the same thing with it I think.
            Press F1...thank me later
            • E Offline
              endpoint
              @gilles said:
              @endpoint said:
              Hi all,
              Thanks in advance,
              J-P
              I already did but I wanted to throw more "fishing lines" in the sea.
              If I got a reply from them I will notify you all.
              J-P.
                Free Soap skin bubble is very similar! πŸ˜‰
                Fill your profil : we don't know what is your version of sketchup! OS ?... πŸ˜„
                Ferrari works inside 2015 so must maybe works also in 2016!
                Tested: works inside 2016 ! β˜€
                Tested: works inside 2017 ! β˜€
                Calculates can take some times! πŸ€“
                • E Offline
                  endpoint
                  I have SU 2017
                  Can you explain how and where you installed the folders/files?
                  Do I have to install more or some other extension(s) in order to let FerrariSketch work?
                  I also get a bunch of error messages:
                  %(#0000BF)[Error:
                  C:/Users//AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `eval'
                  C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `require'
                  C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `<top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require'
                  C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load'
                  C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch.rb:17:in `register_extension'
                  C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>']
                  Thanks.
                  J-P.
                    Go to this post
                    and put the folder / file inside your folder Plugins that you have writed
