    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Smart offset plugin HELP...
    6 Posts 4 Posters 613 Views 4 Watching
    • H Offline
      habashy89
      I have this object and want to add an offset (20mm) all the way around all edges not just the outside edges seen here:
      https://s22.postimg.org/79g3jux35/Screen_Shot_2016_11_23_at_11_17_14_AM.png
      Not sure why it won't allow an offset on the inside edges.. Am I missing something?
      The Sketchup is attached FlowerofLife.skp
      Any help is much appreciated!
      Cheers
      • srxS Offline
        srx
        I made faces inside, selected all and than did offset in both directions with this tool https://www.youtube.com/watch?v=caKEEQop5mk%26amp;feature=youtu.be
        Erase inner edges.
        www.saurus.rs
        • sdmitchS Offline
          sdmitch
          Will this do?
          FlowerofLife.skp
          http://sdmitch.blogspot.com/
            Multiface offset by Remus should make the trick! ๐Ÿ˜‰
            Make the normal Offset first (not made here: it's that you have made ๐Ÿ˜„
            Then fill the holes as you want (draw a big square on the same plane than your form)
            Make intersection as you want
            Select only the "holes" filled (with the trick following)
            Call the plug
            Erase the "holes filled" (no made here: selection with the trick following! ๐Ÿ˜‰
            et voilร ! โ˜€
            A little trick
            Works fine! ๐Ÿ˜„
            • srxS Offline
              srx
              @sdmitch said:
              Will this do?
              I bet you did this with the plugin I proposed ๐Ÿ˜›
              www.saurus.rs
              • sdmitchS Offline
                sdmitch
                @srx said:
                @sdmitch said:
                Will this do?
                No, I never even thought about Multiple Offsets. I "reinvented the wheel" yet again just for this special case.
