    Windows spawn program
    3 Posts 2 Posters 827 Views 2 Watching
    • G
      Garry K
      I've been playing around with the spawn command and found some interesting things. I'm setup as a regular user on Windows 10 and using SU 2016
      I can easily start an external Windows program such as cutmaster.exe using the spawn command providing it is not installed in program files
      filename = File.join('c:', 'program files (x86)', 'cutmaster', 'cutmaster.exe')
      File.file?(filename) returns true and yes the file exists
      spawn(filename) gives me the error 'No such File or Directory'
      If I install the program somewhere else then it spawns.
      However, if I use the old DOS subst command then it will spawn just fine.
      subst y: 'c:\program files (x86)\cutmaster'
      I've tried to run the subst command from within ruby but can't seem to do it.
      cmd = 'subst'
      drive = 'c:'
      folder = File.join('c:', 'program files (x86)', 'cutmaster')
      #{cmd} #{drive} "#{folder}"
      Has anyone any success doing this sort of thing?
      • TIGT
        Try something like:
        cmd = "\"#{filename}\"" spawn(cmd)
        It needs enclosing "", since the string contains spaces...
        Where filename needs to be the full path to the exe file.
        • G
          Garry K
          Of course !! Thanks Tig
