LO 2017 DAT FILE
With SKP, you can import / export keyboard shortcuts from one installation to another. Not so with LO, right?
I did it once. I don't remember how, and deleted the email from SU support that told me which files to copy over. It worked once for me but not another time. I have several custom tool icons. I am no longer using LO so forgot how I copied the info over.
copy shortcuts.xml from this location:
C:\Users\mdurant\AppData\Roaming\SketchUp 2016\LayOut\shortcuts.xml
to this location:
C:\Users\mdurant\AppData\Roaming\SketchUp 2017\LayOut\shortcuts.xmlDo NOT copy the .plo files, that will crash LayOut.
