    Render your SketchUp 2017 models free
    extensions
    1 Posts 1 Posters 5.9k Views 1 Watching
      ashraf
      With the latest release of SimLab Composer 7.2.3 we wanted more users to have access to the real time rendering capabilities of SimLab Composer.
      When installing the new release from the following link
      • Start SimLab Composer
      • When faced with the licensing dialog click Demo, you do not even need to request a trial license.
      • Import your SketchUp (2017 and prior are supported)
      • Add elements with any of the file formats supported by SimLab Composer.
      • From material library, drag and drop rendering material.
      • Click F4 to start real time rendering
      • When you like the results save the image as JPG, PNG with or without background.
      Results can be used for educational and none commercial work.
      If you are using this commercially, a pro license is needed.
      The following video shows how easy it is to start using SimLab Composer to render your SketchUp files.
