    Kernel.system asynchronous on OSX?
    4 Posts 4 Posters 818 Views 4 Watching
    • bomastudioB Offline
      bomastudio
      I want to run an external software (that create a txt file to be post-processed by me) with system() call.
      On Windows all fine. The system(cmd1,...) works, creates the txt file and then my ruby-code processes it as I want.
      On OsX, on the other hand, it seems to work asynchronous: the system(cmd1,...) works and creates the txt BUT my ruby-code try to process the txt file IMMEDIATELY after the system call without waiting for its existence. I have to re-lauch my script, and then it finds the *.txt file and works ok....
      Do you have some experience of it?
      SketchUp 2014,2015,2016,2017 + Windows7 (all ok)
      SketchUp 2015 + OsX 10.8 (bad)
        driven
        it's very hard to ascertain your code's logic from your description...
        can you post a 'working/failing' example...
        system calls work great on osx, but I normally use backticks `` or %x variants...
        john
          system should be blocking. Might it be a different in the command you are invoking?
          • Dan RathbunD Offline
            Dan Rathbun
            I usually use a timer in this scenario, to check when the file exists, then cancel the timer and call the post processing method.
            @tid = UI;;start_timer(0.5,true) {
              if File.exist?(@filepath)
                UI;;stop_timer(@tid)
                post_process(@filepath)
            EDIT(Add): Also, I would usually have a counter variable that gets incremented each timer loop, and a max number of trys, if the file never becomes "ready" then I also exit the timer and somehow display a warning or message that things did not work.
            I'm not here much anymore.
