    Required - place components on vertices
    5 Posts 3 Posters 570 Views 3 Watching
    • john2J Offline
      john2
      Some years back I used component spray for placing components on a mesh's vertices. What free plugin allows me to this today? I tried make fur and ivy plugin but they don't have this feature.
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • srxS Offline
        srx
        You can do it with this http://sketchucation.com/forums/viewtopic.php?t=30506
        www.saurus.rs
          I have a solution if you can find how convert Points Guides in Components! (or groups)
          No problem one by one by hands but...automatically that will much better! ๐Ÿ˜„
          JQL was more speedy! ๐Ÿ‘
          I used ADD Vertex by TIG so use after the Thomthom snippet for a simple thing! ๐Ÿ˜„
          But I want to use the component random replacement by Sdmitch for a more strong thing! ๐Ÿ˜„
          (differents components on a familly of vetex by example)
          So transform each vertex in component or group will be fine!
          Curiously Loose to Group by Chris Fullmer transform only one Guide Point (of a selections of points) in Group! ๐Ÿ˜ฎ
            Seems resolved by Sdmitch! ๐Ÿ˜‰
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=66175
            • john2J Offline
              john2
              thanks. It works ๐Ÿ˜„ ๐Ÿ˜„
