    Invert inverted axes in symetrical components
    extensions
    1 Posts 1 Posters 917 Views 1 Watching
    • IltisI Offline
      Iltis
      Hello,
      If the making process of a component is a duplication by symetrical operation, then "make unique", the axis are inverted.
      (Sorry for this bad english! 😞 )
      This is a problem for me for a plugin containing arcs exportation.
      Do you know how to test the orientation of the axis and how to change it temporarely in my calculations if it's not direct (red, green, blue)?
      I think it must be here in my code :
      # Recursively export faces and exploding groups and components
      def self.write_content(file, selection, tform, z)  # if z==1, it's a 3D export file, if z==0, it's a 2D export file (all the Z values are equal to "0.0" and the normal.z is equal to "1.0"
         selection.each do |entity|
            if entity.is_a?(Sketchup;;Face)
            transform_vector_of_group(entity.normal, tform)
               if z == 1 || (z == 0 && transform_vector_of_group(entity.normal, tform).parallel?(Z_AXIS) && transform_point_of_group(entity.vertices[0].position, tform).z.abs < 0.001 ) # Sketchup tolerance ; 0.0001 inch
                  $number_of_exported_faces +=1
                  write_face(file, entity, tform, z)
                  result = Sketchup.set_status_text $number_of_exported_faces.to_s, SB_VCB_VALUE
            elsif entity.is_a?(Sketchup;;Group) || entity.is_a?(Sketchup;;ComponentInstance)
                  definition = entity.entities.parent
               else
                  definition = entity.definition
               write_content(file, definition.entities, tform * entity.transformation, z)
      Thank you very much.
      Renaud.
