[Plugin] Angular Dimension 2
How would you like it if we made a setting with checkbox (default 'on') for 'Use square for 90deg'?
In response to the above feedback, we have added an option to choose whether right angles are annotated with a small square or with the same format as other angles. The revised version 5.5 beta is available in the plugin store.
To make it easier for us to maintain, we have just completed transfer of this plugin to our joint authorship login in the Plugin Store. To download the latest, please look under "Steve Baumgartner and John McClenahan" authors. This is the same as the 5.5 beta previously published with slbaumgartner as sole author.
PMs and such should now go to slb_jwm.
I've tested the news version and everything is working as expected, thank you for this great updated plugin!
Steve and I have now updated a draft version of the program, with translations into all of the languages in which Sketchup ships for countries using a Latin alphabet.
Before publishing the multi-language version we would like help in reviewing the translations, made (with minor amendments) using Google Translate.
So far, we've done translations for these languages:
French
German
Spanish
Italian
Portuguese
SwedishThere are probably a few mistakes, big and small, in these translations. Neither I nor Steve is a good enough linguist to correct them. Please could a native-speaker of any of these languages review the appropriate page in the attached LibreOffice spreadsheet? It can be opened in LibreOffice or OpenOffice, or Excel.
Please don't change the existing translation, but insert any improved translation suggestions in the last column of one or more of the individual language sheets, identified by the two-letter code in the sheet name.
Please email the suggestions to Steve John <slb.jwm@gmail,com>
Many thanks in advance for anyone who can help.
If you would prefer a different format to ease your process of review, please email your request to us, using the email address above, or by PM to slb_jwm.
Bravo guys this tool should be native thank you
We have just published v6.0 of this extension on the PluginStore. This release adds support for additional languages, improves handling of text placement in many cases, and fixes some minor bugs.
Register LoginAdvertisement
