    [Plugin] Angular Dimension 2
    27 Posts 11 Posters 4.4k Views 11 Watching
    • cottyC Offline
      cotty
      my SketchUp gallery
        slb_jwm
        We have just posted version 5.3 beta, which should handle regions in which comma is used as the decimal point. Please test and let us know if you find problems.
        Note: this release has partial support for French in some of the prompts, but is incomplete in that language and does not yet translate to other languages. John hopes to take that on as a future project!
          blajnov
          Do not put down the value, if the angle is 90 degrees
            slb_jwm
            That is an intentional "feature": the extension follows the convention of marking a right angle with a square. We debated whether that was a good idea or not and decided to try it this way and see what users think. It wouldn't be hard to change...opinions?
            • jujuJ Offline
              juju
              in 2D on paper or diagrammatically it makes sense, but may be confusing when used in a 3D modeling environment
                slb_jwm
                How would you like it if we made a setting with checkbox (default 'on') for 'Use square for 90deg'?
                  slb_jwm
                  In response to the above feedback, we have added an option to choose whether right angles are annotated with a small square or with the same format as other angles. The revised version 5.5 beta is available in the plugin store.
                    slb_jwm
                    To make it easier for us to maintain, we have just completed transfer of this plugin to our joint authorship login in the Plugin Store. To download the latest, please look under "Steve Baumgartner and John McClenahan" authors. This is the same as the 5.5 beta previously published with slbaumgartner as sole author.
                    PMs and such should now go to slb_jwm.
                    • cottyC Offline
                      cotty
                      I've tested the news version and everything is working as expected, thank you for this great updated plugin!
                      my SketchUp gallery
                        johnwmcc
                        Steve and I have now updated a draft version of the program, with translations into all of the languages in which Sketchup ships for countries using a Latin alphabet.
                        Before publishing the multi-language version we would like help in reviewing the translations, made (with minor amendments) using Google Translate.
                        So far, we've done translations for these languages:
                        French
                        German
                        Spanish
                        Italian
                        Portuguese
                        Swedish
                        There are probably a few mistakes, big and small, in these translations. Neither I nor Steve is a good enough linguist to correct them. Please could a native-speaker of any of these languages review the appropriate page in the attached LibreOffice spreadsheet? It can be opened in LibreOffice or OpenOffice, or Excel.
                        Please don't change the existing translation, but insert any improved translation suggestions in the last column of one or more of the individual language sheets, identified by the two-letter code in the sheet name.
                        Please email the suggestions to Steve John <slb.jwm@gmail,com>
                        Many thanks in advance for anyone who can help.
                        If you would prefer a different format to ease your process of review, please email your request to us, using the email address above, or by PM to slb_jwm.
                        Draft translations for Angular Dimension 2
                        • GMthompsonG Offline
                          GMthompson
                          Bravo guys this tool should be native thank you
                          you can learn something everyday by paying attention
                            slb_jwm
                            We have just published v6.0 of this extension on the PluginStore. This release adds support for additional languages, improves handling of text placement in many cases, and fixes some minor bugs.
                            • 2 / 2
