    [Plugin] Angular Dimension 2
    27 Posts 11 Posters 4.4k Views 11 Watching
      slbaumgartner
      John McClenahan and Steve Baumgartner are pleased to issue the initial beta version of a major revision of Steve's Angular Dimension extension. This new version is currently available on the sketchUcation plugin store.
      We have labeled it "beta" because we have only a limited suite of systems to test on ourselves and have found a few issues with particular combinations of OS, SketchUp version, and IE version and settings. We need additional people to try it and report whether it works for them.
      • P Offline
        Maybe adress can help! ๐Ÿ˜„
        http://sketchucation.com/pluginstore?pln=Angular_Dimension_2
          slbaumgartner
          Thanks @pilou, that was an oversight that we hadn't fixed yet!
            slb_jwm
            John and I created a new userid slb_jwm for our joint project (and any future such). If you need to PM us, please use that userid as the target so that we will both see it. Thanks!
              slb_jwm
              No feedback yet, despite numerous downloads of this extension. How is it working for you? Are there problems or shortcomings we need to address?
              Thanks,
              Steve and John
                baz
                Thanks,
                Steve and John
                Haven't had to use it except for testing but seems to work very well. Thanks.
                  db11
                  Used it for the first time today. Works as expected on MacOS (El Capitan) / SU Pro 15.
                  My only feature request would be for it to pick up the Dimension font and colour settings.
                    cotty
                    Great idea to update this often searched plugin!
                    If I click on "Load Defaults", I've get this:
                    my SketchUp gallery
                      slb_jwm
                      @cotty, that's interesting. A couple of followup questions to help us track it down:
                      • did you type anything before getting this error, or did it happen the moment you opened the settings dialog?
                      • is your computer set to a locale that uses comma as the decimal point (we may have overlooked that)?
                        driven
                        cotty, do you use a coma as your decimal separator?
                        john
                          cotty
                          Yes, I do.
                          my SketchUp gallery
                            slb_jwm
                            Thanks, @Cotty! We can see that we overlooked correct handling of comma-style decimals in some places. We'll get right on it.
                              cotty
                              Thank you!
                              ๐Ÿ‘
                              my SketchUp gallery
                                slb_jwm
                                Alas, at this time the SketchUp Ruby API does not expose any way to get these properties from the Dimension objects or the model.
                                  slb_jwm
                                  A brief status report: we are working on automatic handling of '.' vs ',' decimal points throughout the extension. Given how we had implemented the extension, this turned out to be more complicated than we hoped, but we are nearing completion. Stay tuned...
                                    cotty
                                    ๐Ÿ‘
                                    my SketchUp gallery
                                      slb_jwm
                                      We have just posted version 5.3 beta, which should handle regions in which comma is used as the decimal point. Please test and let us know if you find problems.
                                      Note: this release has partial support for French in some of the prompts, but is incomplete in that language and does not yet translate to other languages. John hopes to take that on as a future project!
                                        blajnov
                                        Do not put down the value, if the angle is 90 degrees
                                          slb_jwm
                                          That is an intentional "feature": the extension follows the convention of marking a right angle with a square. We debated whether that was a good idea or not and decided to try it this way and see what users think. It wouldn't be hard to change...opinions?
                                            juju
                                            in 2D on paper or diagrammatically it makes sense, but may be confusing when used in a 3D modeling environment
                                            • 1 / 2
