    [Plugin] Angular Dimension 2
    27 Posts 11 Posters 4.9k Views 11 Watching
      slb_jwm
      John and I created a new userid slb_jwm for our joint project (and any future such). If you need to PM us, please use that userid as the target so that we will both see it. Thanks!
        slb_jwm
        No feedback yet, despite numerous downloads of this extension. How is it working for you? Are there problems or shortcomings we need to address?
        Thanks,
        Steve and John
        • bazB Offline
          baz
          Thanks,
          Steve and John
          Haven't had to use it except for testing but seems to work very well. Thanks.
            db11
            Used it for the first time today. Works as expected on MacOS (El Capitan) / SU Pro 15.
            My only feature request would be for it to pick up the Dimension font and colour settings.
            • cottyC Offline
              cotty
              Great idea to update this often searched plugin!
              If I click on "Load Defaults", I've get this:
              my SketchUp gallery
                slb_jwm
                @cotty, that's interesting. A couple of followup questions to help us track it down:
                • did you type anything before getting this error, or did it happen the moment you opened the settings dialog?
                • is your computer set to a locale that uses comma as the decimal point (we may have overlooked that)?
                  driven
                  cotty, do you use a coma as your decimal separator?
                  • cottyC Offline
                    cotty
                    Yes, I do.
                    my SketchUp gallery
                      slb_jwm
                      Thanks, @Cotty! We can see that we overlooked correct handling of comma-style decimals in some places. We'll get right on it.
                      • cottyC Offline
                        cotty
                        Thank you!
                        my SketchUp gallery
                          slb_jwm
                          Alas, at this time the SketchUp Ruby API does not expose any way to get these properties from the Dimension objects or the model.
                            slb_jwm
                            A brief status report: we are working on automatic handling of '.' vs ',' decimal points throughout the extension. Given how we had implemented the extension, this turned out to be more complicated than we hoped, but we are nearing completion. Stay tuned...
                            • cottyC Offline
                              cotty
                              my SketchUp gallery
                                slb_jwm
                                We have just posted version 5.3 beta, which should handle regions in which comma is used as the decimal point. Please test and let us know if you find problems.
                                Note: this release has partial support for French in some of the prompts, but is incomplete in that language and does not yet translate to other languages. John hopes to take that on as a future project!
                                  blajnov
                                  Do not put down the value, if the angle is 90 degrees
                                    slb_jwm
                                    That is an intentional "feature": the extension follows the convention of marking a right angle with a square. We debated whether that was a good idea or not and decided to try it this way and see what users think. It wouldn't be hard to change...opinions?
                                    • jujuJ Offline
                                      juju
                                      in 2D on paper or diagrammatically it makes sense, but may be confusing when used in a 3D modeling environment
                                        slb_jwm
                                        How would you like it if we made a setting with checkbox (default 'on') for 'Use square for 90deg'?
                                          slb_jwm
                                          In response to the above feedback, we have added an option to choose whether right angles are annotated with a small square or with the same format as other angles. The revised version 5.5 beta is available in the plugin store.
                                            slb_jwm
                                            To make it easier for us to maintain, we have just completed transfer of this plugin to our joint authorship login in the Plugin Store. To download the latest, please look under "Steve Baumgartner and John McClenahan" authors. This is the same as the 5.5 beta previously published with slbaumgartner as sole author.
                                            PMs and such should now go to slb_jwm.
