    How to build this model in SketchUp?
    26 Posts 6 Posters 10.8k Views 6 Watching
    • chippwaltersC Offline
      chippwalters
      Does anyone have an idea on how to automatically/algorithmically build this in SketchUp using a bitmap (or other way) to drive the distribution of randomimzed height boxes (or other shapes)?
      Perhaps some sort of combination of Scatter and other plugins? Thanks for any cycles spent cogitating...
      https://dl.dropboxusercontent.com/u/3788438/3D/howtodothis.jpg
      Currently working with Cross-Reality technologies
        How about Chris Fullmer's Greeble plugin? It's in the Extension Warehouse.
          chippwalters
          Aha! Thanks for that! I had forgotten about that plugin-- used it years ago. Very nice and much appreciated πŸ˜„
            Take also a look to Random protrusion By Sdmitch! πŸ˜‰
            and my various solutions! πŸ˜‰
            http://sketchucation.com/forums/download/file.php?id=89810&mode=view/rokbox.jpg
              Personnally I will use the fabulous Random Component replacement by Sdmitch πŸ˜„
              (because you can all control! (number, color etc...)
              The best in my opinion! πŸ‘
              It's a little tricky but very easy! 😎
              Only constraint: you must draw elements of the "Source" !
              (Grow by Tig for make the "stairs of Box" components Source )
              Target is here the "yellow boxes rectangle" Will be in your case anything you want! (DSN)
              http://www.3dsaloon.fr/phpbb3/download/file.php?id=3128&t=1
              First version of Projection by Didier Bur has a random creation! πŸ˜‰
              Joint Push Pull Interactive by Fredo6 has also a randomdom creation! 😎
              Minute 6.30
                A funny Process : Show Hidden Geometry
                SU TGI 3D (free) for draw Cross Sections of a volume
                Select Only faces (not the perimeter) Selection Toy by Thomthom
                Fredo Joint Push Pull "N" (with random)
                You can take of course any volumes! (DSN)
                One by one for the Cross Sections
                All in One for the Joint Push Pull Random protrusion! (Fredo) πŸ€“
                  Chip, if you just stall long enough, Pilou will have the work done for you. πŸ˜„
                    Oh c'mon, Pilou! Just a few more minutes. πŸ˜„
                    Sleep well.
                      Impossible! it's a pity! I must go to bed! πŸ’š
                        My eyes close themselves! 😍
                          I understand that!
                            chippwalters
                            Dave, I'm pretty sure you are right. Just in case Pilou wasn't trolling these boards, I posted the same basic challenge at the MoI3D forum-- which he was one of the first to answer there too!
                            Frenchy, Thanks much for taking the time to show me so many examples! Much appreciated πŸ˜„
                              chippwalters
                              Dave,
                              Playing with Greeble. How did you get the originating grid in order to use Greeble? Having a tough time getting there...
                              • cottyC Offline
                                cotty
                                @chippwalters said:
                                Dave,
                                One example with ThrowTo plugin...
                                my SketchUp gallery
                                  Chip, I just made a flat grid and deleted the edges to get the D shape. I like Cotty's idea for creating the shape of the letters as well as the background blocks. I didn't have Throw To installed so I didn't think of it for this.
                                    Else for Cubify the D πŸ˜‰
                                    Voxelize by TheDro
                                    Draw a "D" in any font : Make a Group
                                    Voxelize by theDro
                                    Take the Top Line of cubes: Move it
                                    Explode
                                    Select Only Top Faces (not perimeters) (Selection Toy) by Thomthom
                                    Joint Push Pull "N" (random as you want) by Fredo
                                    et voilΓ  πŸ’š
                                    PS Ground will be of course trivial! πŸ˜‰
                                    The 3 letters D N S can be voxelizing in the same time but careful heavy calculation!
                                    Depending of the scale of voxelisation! πŸ€“
                                    Edit : in fact no: it's Speedy Light : see following posts! πŸ˜„
                                      If you take the 1/4 height with Voxelise
                                      that is speedy light for all letters in the same time! πŸ’š
                                      Take the Top cubes, Select the faces Joint Push Pull "N" (random) etc...as you want! β˜€
                                      (for your exact result asked at the first post)
                                      After moving the original group
                                      Color by Sdmitch Plugin
                                        chippwalters
                                        Thanks everyone who contributed. Much appreciated.
                                        Frenchy, thanks for the Voxelize mention. I started using it, but then just couldn't figure out how to easily match the logo with the underlying grid while easily keeping things separate.
                                        Instead I used Cotty's advice and quickly created a grid comprised of single GROUPED sqares, then placed the logo beneath it and another plane beneath it as Cotty did and projected to Infinity using the Throw It plugin. Needed to keep the squares GROUPED or else they wouldn't 'throw' correctly.
                                        Once I had individual square poly groups in place, I then EXPLODED them and then creatde a single mesh Group-- one for the base and one for the logo.
                                        From there it was simple to apply Greeble to the group to get the effect I wanted. On the logo, I used the 'keep top faces grouped' Greeble option so that I could then AGAIN Greeble to get a slight bevel. I would've done the same for the base, but Greeble took so long to work through it, I decided to leave as is. (I don't even know how long as finally I just went to bed).
                                        Here's the final. Now off to create a KeyShot rendering of it.
                                        https://dl.dropboxusercontent.com/u/3788438/3D/GreeblesPILOUadj.jpg
                                          @Chipp
                                          Why Not! πŸ˜„
                                          Just make 2 goups!
                                          Letters and a flat ground
                                          And play with the "N" random range of this flat one with the Joint Push Pull "N"! πŸ˜‰
                                          Of course fonts must have inbetween letter multiple of cube unity!
                                          As it's groups you can move them as you want for any positions x,y,z if adjusments are necessary!
                                          Here my plane is 1 m under the letters - so my range can be for example 0.8 m ---> 1 m
                                          Thanks to Fredo for this marvelous tools! 😎 Notice the range random! πŸ€“
                                          (in this video my cubes'ground are rectangles! πŸ’š It was just for the concept! β˜€
                                            chippwalters
                                            And the render...
                                            https://dl.dropboxusercontent.com/u/3788438/3D/PILOUgreeble177sm.jpg
                                            • 1 / 2
