    Dropping to terrain: nothing happens
    extensions
    3 Posts 2 Posters 940 Views 2 Watching
    • G Offline
      gregswk
      Hi!
      -I used Autocad Map 3d to generate some buildings with their proper heights attaching a shapefile. Then I converted polygons to solids using -convtosolid command.
      -After that I saved as .dwg to export the buildings to Sketchup.
      -All the solids have been imported perfectly, each one as a group (already named like "Group#322").
      ~AND HERE COMES THE TROUBLE!~
      -I can't use drop to terrain plugins like DropGC and Raytracer. I select the groups and click the plugin but nothing happens. BUT if I explode and regroup them (one by one), everything works normally. WHY??
      -Ive tried making components and renaming but nothing solved this problem.
      WHAT IS HAPPENING? HOW CAN I SOLVE THIS? SOMEONE HELP ME PLEASE! :<
      I dont want to ungroup and regroup each solid... unless there's a script to do this automatically, which would solve my problem too.
      Thank you for reading and i hope you can help me πŸ˜„
        Can you send 2 groups .skp ? (save as v6)
        • G Offline
          gregswk
          Here it is!
          DROP TO TERRAIN_SKP6.skp
