    [solved]Syntax problem with a Sketchup::Face
    4 Posts 2 Posters 868 Views 2 Watching
    • IltisI Offline
      Iltis
      Hello,
      Could you tell me what's wrong in this code? 😞
      (Z is a parameter. If z=0, I want only the faces in the Z=0 plane)
      selection.each do |entity|
            if entity.is_a?(Sketchup;;Face)
      				 if z == 1 || (z == 0 && entity.normal.x.abs < 0.00001 && entitiy.normal.y.abs < 0.00001 && entity.vertices[0].z.abs < 0.000001 ) # Sketchup tolerance ; 0.0001 inch)
      In the Ruby console :
      Error: #<NameError: undefined local variable or method `entitiy'
      Thank you for your help.
      BR,
      Renaud.
      • IltisI Offline
        Iltis
        OK, it's a typo! entitiy instead of entity! Shame on me!
          A common thing !
          I often do it.
          You could simplify your code thus:
          selection.grep(Sketchup;;Face).each{|face|
            if face.normal.parallel?(Z_AXIS)
          This collects all selected faces and if they are 'flat' you do something...
          The parallel? check has built-in tolerance...
          • IltisI Offline
            Iltis
            Thanks TIG! 😄
