    Center the view on selected object
    5 Posts 3 Posters 1.4k Views 3 Watching
    • ZackJordsZ Offline
      ZackJords
      In Autodesk Maya(not quite sure about others) you can press F or A to center the camera view on selected object.im not quite sure you can do this on sketchup or not.after using sketchup for awhile (7years) i keep wondering either this could be complish via plug ins or not..Thank you
      • sdmitchS Offline
        sdmitch
        In Sketchup, it requires just a little Ruby code
        mod = Sketchup.active_model
        sel = mod.selection
        vue = mod.active_view
        bb = Geom;;BoundingBox.new
        sel.each{|e|bb.add e.bounds}
        cam = vue.camera
        cam.set cam.eye,bb.center,Z_AXIS
        You can add
        vue.zoom sel
        if you want a closeup view.
        http://sdmitch.blogspot.com/
          ZackJords
          Thank you so much, Sdmitch. It work like charm. Ita possible to assign shortkey to this code? Much appreciated
          • N Offline
            numerobis
            zoom selection
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=1544%26amp;p=472627
              ZackJords
              Thank you so much Numerobis and Sdmitch for your time.cheers
