    DOCUMENT UPDATE IN LO 2016
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    4 Posts 3 Posters 14.7k Views 3 Watching
    • P
      pipingguy
      Document update normally is a 6 click procedure. (file>document setup > references > select file > update > close. Another way is to context click a viewport - but my viewports are often locked, thereby adding steps. I was happy to discover a shortcut as well as a tool to make it a one click procedure. However - they fail to work. 😞
      UPDATE DOCUMENT FAIL.pdf
      • brettsichellodesignB
        brettsichellodesign
        This should speed up the process a little:
        • P
          pipingguy
          THANKS...THEY FINALLY FIXED IT
            What do you mean they finally fixed it? It's worked that way all along.
