    Problems with polygons
    Scheduled Pinned Locked Moved Organic Modelling
    3 Posts 3 Posters 11.1k Views 3 Watching
    • K Offline
      kellenraidfractal
      I just downloaded and began to use SU2015. I cannot make a circle or other polygon. I did just what I did in earlier versions, but when I click to change the diameter, it disappears. Is there a setting I need to change?
      • BoxB Offline
        Firstly, if you are starting with something new, why aren't you using 2016?
        Secondly, what do you mean when you say click to change diameter? What do you click and what disappears?
        • bazB Offline
          baz
          Check your model units?
