    Free Polyhedron generator
    8 Posts 4 Posters 8.1k Views 4 Watching
    • Alan FraserA Offline
      Alan Fraser
      As the title says...a handy little Windows program that will generate a bewildering number of regular polyhedra. If you're after a specific one, you may have to Google then enter its Wythoff symbol.
      It will output either a pdf pattern to make a paper model....or amazingly...export a Ruby script that you can enter into the Console to generate the geometry in SU.
      https://sourceforge.net/projects/gsolaar/
      Pasting the Ruby script into the Console will place a gsolaar menu item for that particular polyhedron at the bottom of the Extensions menu.
      The UI
      The generated Ruby script
      The generated SKP
      3D Figures
      • sdmitchS Offline
        sdmitch
        The puts statements contain multi-byte characters that may need to be edited or removed.
        http://sdmitch.blogspot.com/
          Alan Fraser
          It doesn't seem to make any difference. The polyhedron is created whether the statements are left in French accented or translated to English.
          3D Figures
          • sdmitchS Offline
            sdmitch
            It would not load in SU2014 without removing them.
              It will fail in newer SketchUps >=v2014.
              The file is NOT encoded as UTF-8 - it's ANSI.
              It's also poorly formed code - e.g. without its own module, global-variables etc.
              Here a better / 'compatible' version...
              IcosahedralConvexIsogonalPolyhedron.rb
                Alan Fraser
                Well gents, I admit that the coding does look a little primitive, but what can I say? It's not my coding...and it works for me in Pro 2016 v16.1.1449. and the skp is up there to prove it (although I think I saved it in SU 2015 for non-upgraders) I notice that no one has actually downloaded the end result yet.
                Thanks for improving it TIG. Do you think you could throw in some parametrics too? πŸ˜‰ (BTW, I see that guy on the Trimble forum is still at it. I've never come across anyone so unwilling to admit a mistake)
                3D Figures
                  Funny πŸ˜„ the Tig file - (originals generated don't work for me 2016-2015 Make)
                  I have no more my old versions of SU (6-7)! How big is my distress! πŸ’š
                  PS Seems the program can be installed in English, French and...Breton! 😲
                  Multiple Face Offset by Remus, Inverse Selection by Tig Joint PushPull by Fredo6
                    Alan Fraser
                    I don't have much use for this myself, but to anyone dealing with geodesic structures it looks the biz. It seems quite new...Donateware.
                    http://myweb.tiscali.co.uk/oaktree/geodesica/
                    Some YouTube vids
                    https://www.youtube.com/channel/UCzsp1DWUkWjK312s7JKdO6g/feed
                    3D Figures
