    Piano Room
    32 Posts 8 Posters 6.4k Views 8 Watching
    • G
      garystan
      Hi everybody :
                     I need some advice on this one.   I'm having a problem with scaling the scene.   In this one, either the sofa and piano are too small.  Or the credenza and electronics on it are too big.  I kept looking at it, and I couldn't decide. But, it does seem to be "out of scale".  In that sense, it doesn't seem like a smooth transition from left to right in the pic.  Also, I'm not done with it yet.
        garystan
      • tuna1957T
        tuna1957
        garystan, try searching the internet for real world dimensions of the various objects. check them against the models dimensions. scale up or down as needed. one more thing , having a corner so close to the center of the scene rarely looks quite right. play around with your position in the scene until you find the "sweet" spot.
          You are improving, getting better with the furniture etc. If the piano is a 'grand' it needs to be bigger. https://en.wikipedia.org/wiki/Piano. The sofa is difficult to size as they are all different but a quick look around might give a better idea of the average.
          Keep going, you are on the right track, as for the setting of the scene it is something of a trial and error process but again take a look at the architecture sites and you will see a pattern of sorts.
            Access Denied
            (www.bluebookofpianos.com)
            • soloS
              solo
              Composition is key in any image, be it a photo or a render.
              Here is a handy tip:
              http://www.solos-art.com
              • pbacotP
                Twilight has a tool built-in just for trying out the thirds in a scene and setting up the camera.
                • soloS
                  solo
                  Thea for SU also has it available
                  • ntxdaveN
                    ntxdave
                    Thanks for sharing the video Pete. Some good advice.
                    Press F1...thank me later
                      Even if the cameraman did use different parts of the windmill to align in each part of the video.
                        404 Not Found
                        (www.pixatecreative.com)
                          Purely academic and subjective! πŸ˜„
                          More barrier for one, more grass for the other! πŸ’š
                          Not sure that the first is more dynamic!
                          All tastes are in nature! πŸ˜„
                          • G
                            garystan
                            Hey guys :
                                            I watched the video. It has some good pointers.  I  cropped the rendering with the "positioning" mentioned in the video.   I hope this looks better.
        garystan
                            • G
                              garystan
                              Hey guys :
                                              Hope I'm making any  sketchucation mistakes.  I just wanted to let you guys know that I watched the video.  Some good  ideas there. So I kinda adjusted the  Piano Room....thinking about the postioning.   Hopefully, this is an improvement.
        garystan
                              • tuna1957T
                                tuna1957
                                garystan, the scale of the piano is still bothering me. did a quickie search. The measurement from the floor to the bottom of the piano "case" is approximately 28 1/2" ( where your knees go when playing ), from floor to the top of the "lid is 40".your bookcase/credenza seems to dwarf the piano in size. most low bookcases and credenza's are usually 28" - 30" high on average. the next thing is just personal preference. I'd move the camera position to the right where you would have a more raking view of the wall with the bookcase. I'd rotate the piano a little clockwise so your not looking so straight on at it. It would also bring more of the sofa into view. All that said" by george your standing at the plate swinging at the pitches". Keep it up it's how you learn and get better. πŸ‘
                                • pbacotP
                                  As far as scale goes, since you asked. I am just imagining someone sitting on that couch and the on the piano seat. Someone who would sit on that seat might have their legs dangling at the couch.
                                  How wide is the piano? how long is your guitar?
                                  • G
                                    garystan
                                    quote="tuna1957"]garystan, the scale of the piano is still bothering me. did a quickie search. The measurement from the floor to the bottom of the piano "case" is approximately 28 1/2" ( where your knees go when playing ), from floor to the top of the "lid is 40".your bookcase/credenza seems to dwarf the piano in size. most low bookcases and credenza's are usually 28" - 30" high on average. the next thing is just personal preference. I'd move the camera position to the right where you would have a more raking view of the wall with the bookcase. I'd rotate the piano a little clockwise so your not looking so straight on at it. It would also bring more of the sofa into view. All that said" by george your standing at the plate swinging at the pitches". Keep it up it's how you learn and get better. πŸ‘
                                    /quote
                                            tuna1957 :
                                                       I did some re-arranging.  Resizing the furniture.  Adjusting the view......etc............. Hopefully, this looks better.
        garystan
                                    • G
                                      garystan
                                      solo :
                                      I did a little work on it. Re-arranging the furniture.....point of view...scale...etc. Hopefully, this looks better. (And, keeping the 2/3 rule in mind).
        garystan
                                      • tuna1957T
                                        tuna1957
                                        ditto what pbacot said. a few comments, the corner of the windows still catches my eye first, then I go to the various objects in the room. Pick the object that you want to be the focal point and adjust your view so that is what the eye is drawn to first. I'd increase the field of view some so you have more of the left side of the scene in view. I'd try lowering the eye height a little maybe. It just take trying different angles and such until you hit that sweet spot. Keep experimenting .... πŸ‘
                                        • G
                                          garystan
                                          @pbacot said:
                                          Good work! Feeling much better with piano etc. The exterior picture is the wrong perspective for the room. You'd want the horizon lower and the vanishing points sort of going along with the window grid.
                                          pbacot :
                                                      I wasn't sure about where to set the horizon.  I didn't want to give the impression that the room was high up.  As for the pic itself.......I wasn't sure about that either.   Thanks for your comments (advice).
        garystan
                                          • G
                                            garystan
                                                  tuna1957 :
                                                              Taking a closer (and second) look at it.  Yeah.....I think you're right about the perpsecive of the background.  I take it......this part of the learning process.....
        garystan
                                            • 1 / 2
