    Giving images different name with export image
    3 Posts 2 Posters 545 Views 2 Watching
    • X
      xi21lipa
      Hi, I'm working on 'export image' by myself and the result was not bad.
      Now, I'm trying to export some images with different name. The problem is, I already set up the specific name. I couldn't get next image with different name before I change the name in code.
      Maybe, I have to treat the name as variable but don't know how to do
      could you please help me with it? Here, I'm sharing the code
      require 'sketchup.rb'
          def exportimage
            model = Sketchup.active_model
            entities = model.entities
            view = model.active_view
            # Set the camera properties
            eye = [0, 0, -1000]
            target = [0, 0, 0]
            up = [0, 100, 0]
            # Create the camera and make it active
            cam = Sketchup;;Camera.new eye, target, up
            view.camera = cam
            view.zoom_extents
            # Set file property
            keys = {
              # Naming file
              ;filename => "c;/temp/_image.png",
              # Pixel setting
              ;width => 500,
              ;height => 500,
              # Tranparent setting
              ;transparent => false
            view.write_image keys
          end # def ExportImage
      if( not file_loaded?("exportimage.rb") )
      add_separator_to_menu("Plugins")
      if $submenu!=nil
      $submenu.add_item("ExportImage") { exportimage }
      else
      UI.menu("Plugins").add_item("ExportImage") { exportimage }
      file_loaded("exportimage.rb")
      with the code. All the name of images I produced was '_image'. I would like to get images have different name without changing the line "c:/temp/_image.png", in the code.
      • D
        driven
        you can't not change that line, "c:/temp/_image.png" IS your image name...
        each new one will overwrite the previous...
        if you want different names that line has to change...
        john
        • X
          xi21lipa
          john
          Then, what if I don't specify an image file path? Only the name and extension of image file will be remained and it looks like it can be treated... using #{name}
