    LAYOUT Line dashes and arrows
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    8 Posts 4 Posters 14.4k Views 4 Watching
    • pbacotP Offline
      More options or ways to create arrows for text and dimensions would be nice. The current ones don't go with any style I use. The ability to create heavy arrow strokes, independent of line weight would be great.
      The dashes are mostly unusable. Why are the dashes linked to line weight? I can't get anything resembling the dashes I typically use in CAD, dashes that provide a reasonable image. The very many patterns provided are not nice even if they did work with heavier line weights.
      I realize the true rendering of dashes is a convoluted task, but it's something that LayOut needs. Dashes should be solid at intersections (points on a polygon), they need to be cosistent though fit to the line length.
      • utilerU Offline
        utiler
        Just Curious...
        • JQLJ Offline
          JQL
          Adding to that that dashes and other line styles should also display as they are printed. They change scale when zooming.
          www.casca.pt
          Visit us on facebook!
          • utilerU Offline
            utiler
            +1!!!!
            Just Curious...
            • bazB Offline
              baz
              πŸ‘
              Also, I hate that my carefully chosen Typeface appears bolder when printed to PDF.
              • JQLJ Offline
                JQL
                I've never noticed that, but I only use 2 "carefully chosen Typefaces" in Layout.
                Let's not talk about text here though! There's so much to say about that too! πŸ˜„
                www.casca.pt
                • pbacotP Offline
                  I think we may be seeing some effects that will be different on different platforms or computers. I don't see quite the same things others are mentioning but the way the line dashes cannot be adjusted, depending on the line thickness, seems universal. Draw a rectangle and try to give it some thickness and a dash, and it doesn't look like anything but some random short lines.Screen Shot 2016-06-16 at 7.28.38 AM.pngScreen Shot 2016-06-16 at 7.27.08 AM.png
                  • JQLJ Offline
                    JQL
                    1. When this happens you clearly know something is wrong and needs fixing. This is bad.
                    2. However when this happens, people don't notice the tiny deviation and look at the error like it's correct. Much worse imho.
                    www.casca.pt
