    Generate Centerlines
    11 Posts 6 Posters 1.7k Views 6 Watching
    • bmikeB Offline
      bmike
      Is there a plugin out there that will generate centerlines of components? I'd like to window a bunch of components and have it generate centerlines in order to speed up sending files to an engineer for analysis....
      Typical model:
      I'd be happy to do this in '2d' in pieces, so I could generate centerlines for a typical bent:
      mike beganyi design + consulting llc
      • sdmitchS Offline
        sdmitch
        A rather interesting problem. Could you possible post a "typical" model version<=2014?
        http://sdmitch.blogspot.com/
        • bmikeB Offline
          bmike
          Here's a V8 attached.
          trusses-sample-centerlines.skp
          • G Offline
            glro
            Typical model:
            [attachment=1:vg3or3yz]<!-- ia1 -->Screen Shot 2016-06-14 at 11.31.37 AM.png<!-- ia1 -->[/attachment:vg3or3yz]
            [attachment=0:vg3or3yz]<!-- ia0 -->Screen Shot 2016-06-14 at 11.46.39 AM.png<!-- ia0 -->[/attachment:vg3or3yz]
            you could add the centrelines in the components at first, so you
            wouldn't have to add them
            • bmikeB Offline
              bmike
              @glro said:
              Typical model:
              [attachment=1:1x021yd5]<!-- ia1 -->Screen Shot 2016-06-14 at 11.31.37 AM.png<!-- ia1 -->[/attachment:1x021yd5]
              [attachment=0:1x021yd5]<!-- ia0 -->Screen Shot 2016-06-14 at 11.46.39 AM.png<!-- ia0 -->[/attachment:1x021yd5]
              which would render them non solid, so useless for using any of the solids tools.
              • G Offline
                glro
                @bmike said:
                @glro said:
                Typical model:
                [attachment=1:mpqk94i3]<!-- ia1 -->Screen Shot 2016-06-14 at 11.31.37 AM.png<!-- ia1 -->[/attachment:mpqk94i3]
                [attachment=0:mpqk94i3]<!-- ia0 -->Screen Shot 2016-06-14 at 11.46.39 AM.png<!-- ia0 -->[/attachment:mpqk94i3]
                unless you put the centerline on a different layer you could easily remove
                just an idea...
                • bmikeB Offline
                  bmike
                  yes, just an idea, but my flow is to build the model and take it to a certain point before handing off to an engineer for review (often getting close with my own calculations, as well as having input from the architect / client / etc.
                  putting the lines on a separate layer wouldn't really help me out, as the lines still break solid, wether the layer is on or off, and i typically use the solid tools quite a bit before I get to the point of needed to generating the centerlines.
                    dtrarch
                    Mike
                    Make them construction lines that can be converted to "line"
                    There are 2 or 3 plugins that do this now.
                    d
                      Can we have a very simple image(s) of what do you want exactly as center lines? Short.. long ....
                      (on the 2D or 3D images above)
                      • G Offline
                        glro
                        @dtrarch said:
                        Mike
                        d
                        good idea
                        i tried: it works
                        Even with a construction line inside the component, operations are possible on volumes with sketchup pro
                        the modified component becomes a group, but if the goal is to get the centerlines only, just delete the surfaces and convert the construction lines into lines
                        just one idea plus just one idea...
                        bool
                          driven
                          as a basis for a plugin I would use this workflow...
                          copy selection into new drawing...
                          move all axes to centre,centre, bottom [e.g. TT_axes tools]...
                          create a proxy with same axes, a single line with the length of the most used element and hidden square at one or both ends [to allow scaling]...
                          select all and replace with proxy...
                          scale each proxy to intersection points...
                          this workflow could possibly be automated, but would still require tweaking by eye and addition of missing bits...
                          tree steps...
                          trusses-sample-centerlines_001.skp
                          john
