    [Plugin]Hide Invisible Polygons and Component
    2 Posts 2 Posters 549 Views 2 Watching
    • ithilI Offline
      ithil
      Hi All!
      This plugin helps to finde and remove invisible polygons/components/groups. Not visible objects are transferred to the new layers. If you want this layers can be removed together with its contents.
      Test type:
      Full - check the visibility of polygon (component) in addition to 5-axis type with the bottom image. The most accurate / slowest method
      Camera - the same, but checks only one direction from the camera. The fastest method.
      Short - blue, green file axis and axis of the camera.
      Visibility of components / groups checked by 8 points - the corners of the bounding box. If you see at least one point of the component can not be hidden.
      Visibility polygon is checked only for points. Not for the area.
      Menu
      Extensions(Plugins) >> Ithil Tools >> Hide Invisible Polygons and Component
      ithil_hide_invisible_polygons.rbz
        rv1974
        Thanks for sharing!
        'hide invisible' doesn't sound logical. maybe 'remove'?
