    Separation of code and image display in webdialog
    1 Posts 1 Posters 389 Views 1 Watching
    • H
      hanl000
      I'm currently doing work on webdialog and have two problems now
      This is the code I have made
            unless file_loaded?(__FILE__)
               toolbar = UI;;Toolbar.new "Icons"
               cmd = UI;;Command.new("Create_Box") { icons }
               cmd.small_icon = cmd.large_icon = "icon.png"
               toolbar = toolbar.add_item cmd
               toolbar.show unless toolbar.get_last_state==0
               file_loaded(__FILE__)
            def icons
               dlg=UI;;WebDialog.new("Icons", false,"WDID",200,300,10,10,true)
      	dlg.add_action_callback("Orbit") {|d, p|Sketchup.send_action "selectOrbitTool;"}
      	dlg.add_action_callback("Hide") {|d, p|Sketchup.send_action "editHide;"}
      	dlg.add_action_callback("Unhide") {|d, p|Sketchup.send_action "editUnhide;"}
      	dlg.add_action_callback("Select") {|d, p|Sketchup.send_action "selectSelectionTool;"}
      	dlg.add_action_callback("Hidden") {|d, p|Sketchup.send_action "viewShowHidden;"}
      	dlg.add_action_callback("Undo") {|d, p|Sketchup.send_action "editUndo;"}
      	dlg.add_action_callback("Redo") {|d, p|Sketchup.send_action "editRedo;"}
               html = <<-HTML
               <!DOCTYPE html>
               <html>
                  <head>
                     <meta charset="utf-8" />
                     <meta content="IE=edge" http-equiv="X-UA-Compatible" />
      						    <script>
      							function Select() {window.location = "skp;Select";}
      							function Undo() {window.location = "skp;Undo";}
      							function Redo() {window.location = "skp;Redo";}
      							function Orbit() {window.location = "skp;Orbit";}
      							function Hide() {window.location = "skp;Hide";}
      							function Unhide() {window.location = "skp;Unhide";}
      							function Hidden() {window.location = "skp;Hidden";}
      						    </script>
                  </head>
                  <body>
      		<table>
                             <td><button onclick="Select();"><img src="Webdialog/images/Select.png"></img></button></td>
                             <td><button onclick="Undo();"><img src="Webdialog/images/Undo.png"></img></button></td>
                             <td><button onclick="Redo();"><img src="Webdialog/images/Redo.png"></img></button></td>
                             <td><button onclick="Orbit();"><img src="Webdialog/images/Orbit.png"></img></button></td>
                             <td><button onclick="Hide();"><img src="Webdialog/images/Hide.png"></img></button></td>
                             <td><button onclick="Unhide();"><img src="Webdialog/images/Unhide.png"></img></button></td>
                             <td><button onclick="Hidden();"><img src="Webdialog/images/Hidden.png"></img></button></td>
      		</table>
                     </form>
                  </body>
               </html>
               HTML
               dlg.set_html(html)
               RUBY_PLATFORM =~ /(darwin)/ ? dlg.show_modal() ; dlg.show();
      Once I run this code in Sketchup, One icon opens webdialog is seen. The problem is, icons correspond to each basic tool are not displayed. I correctly specified the pathway to the folder where image files are contained. Please have a look at the attached file. This is what I'm seeing now. My expectation was icons are displayed well.
      For better work, I would like to separate HTML code from the whole code. The codes HTML and Ruby API are mixed look messy. In the code, HTML part is written together and I want to substitute 'Sketchup.find_support_file "Pathway1/Pathway2.html'(or other codes can load external html file) for the internal HTML in main code. How can I proceed this work?
