    FlexSlat - Dynamic Component
    5 Posts 2 Posters 9.6k Views 2 Watching
    • halroachH
      halroach
      **Presenting FlexSlat - The second proud member of the Flex-Family! 😉
      Following FlexWindow, FlexSlat is also ultra light, simple and versatile – for quick generation of...
      slat variations!**
      To purchase FlexSlat please visit:
      http://frandzel3d.com/flexslat/
      FlexSlat consists of the following components:
      • frame profiles
      • frame corners
      • slats (2 separate instances for optimized usage – see ‘economode’ below)
      • Sketchup 2015 and up
      Usage:
      • scale or type in measurements
      • specify dimensions – frame and slats
      • specify spacing and rotation in X,Y,Z +- random positioning and rotation
      • set frame to 0 – frame hidden.
      • inset guide – specify distance for easy placement
      • frame guide – toggle guide visibility for when frame = 0.
      • offsets – to improve positioning
      • slat – length extension – extend slat edges until flush with frame.
      • slat – reduction – reduce amount of slats from top and bottom.
      Interact tool:
      • on slat – redraw slat position/rotation
      • on frame – redraw all
      Notes:
      Y/Z rotations:
      • OFF – (‘economode’) – Y/Z rotations disabled. Component file size is kept to a minimum of 10 component instances no matter how many slats are generated.
      • ON – Y/Z rotations enabled. Each new slat generated adds an additional component instance to the model. Highly Recommended to ‘purge unused’ when done generating.
      • “no-dims” version included – for multiple component edits while maintaining original dimensions.
      • “drag-n-drop” version included – drag from folder or components library directly into model with no need to explode.
        I'd love to hear comments and suggestions for further development & improvement 😄
      A member of the Flex-family of Sketchup dynamic components.
      Version History:
      1.0
      first version
      component options - click to enlarge
      FlexTools - Super Quick Windows, Doors, Slats...
      • halroachH
        halroach
        FlexSlat 1.0 now also in Traditional Chinese! - 含繁體中文版本
        Just a little update. FlexSlat 1.0 and FlexWindow 2.0 are now available in Chinese too!
        If you have purchased these, and wish to download the Chinese version, access the same link from the email you received upon purchase.
          Random option is very funny for simulate broken things! 😎
            Result can be used with Random Replacement by Sdmitch! 😄
            • halroachH
              halroach
              FlexSlat 1.0 Now in Spanish too!
              Special thanks to Rafael Teresa for his quick translations!
